Mary C wrote:I am using canvas over foam and cotton material on the inside for my walls, NO wood. I bet mine will outlast me!!!!I will save about $75. doing that. I priced everything even the box of screws and everything. I am building thrifty. I was in an area a couple of days ago and saw foam being used in construction was told to wait till Wed to see if they have any left overs. If you stop and ask you might get lucky if you don't you won't get anything. I have to get the trailer built by Monday, test it out Tuesday and go to see if they have any leftovers on Wed. Nothing ventured, Nothing Gained.
Mary C.
bonnie wrote: ... half the adventure is venturing out into that world.
Irving wrote:Thought I might get a better response on this here:
So I am building my walls with 1.5" foam and 1/8" hard fiberboard on the inside and most likely 1/4" OSB (chip board) on the outside. I am going to be covering the entire outside and bottom with canvas and tightbond 3.
I'm still a bit hung up on using the OSB board. I almost bought a bunch of 11/32" plywood but decided it was too heavy and put it back.
Should I be talked out of using 1/4" OSB board? Any good reasons not to use it? It is just so cheap at $9.50 for a 4x8 sheet and it's quite lightweight. I'm having a tough time finding inexpensive 1/4" plywood in my area.
Wolfgang92025 wrote:Foe some reason I don't think its mold.
More like it is ink/dye from the info on the foam that got wet and bleed through the canvas. That's my 2 cents worth......
Edit...
Take a piece of scrap foam, smear some glue on it, and see if the glue starts to change color...
Mary C wrote:It is possible that the ink on the foam had some extra spots It probably is not mold but in the future wipe down the foam with a mixture of one to four, Clorox to water mixture on a rag. I am doing it just to be careful. so I am funny I wipe down everything with it though. you could use Clorox wipes too. I don't believe it is mold either. Did you dispense with the wood on the outside?
Mary C.
