What are you using for door hinges? Sources?
Postby Martinjmpr » Thu Mar 28, 2013 2:03 pm
One thing I want to get rid of is the cheap looking piano hinge on the side door:
So what kind of hinges are people using? I've seen the plastic hinge, but I'm leery of its durability.
Is anybody running a marine-type hinge? Any pics or sources?
Thanks in advance! :D
Martin and Liz and our new T@B Clamshell "Livia"
Our old Teardrop "bubbles"
Bubbles version 2.0 build thread!
Our Facebook group:
Colorado Teardroppers and Tiny Trailers Camping Group (FB)
States we've visited with Bubbles and Livia: Image
Martinjmpr
Re: What are you using for door hinges? Sources?
Postby KCStudly » Thu Mar 28, 2013 3:01 pm
http://www.mcmaster.com/#cadinlnord/12575a72/=m2ttwu
Lift off stainless steel. Screws go into the jambs and are inaccessible when the doors are locked closed.
The seal does need to be on the inner surface of the door to use them.
Postby Dean in Ct. » Thu Mar 28, 2013 3:54 pm
I'm using some old bronze marine hinges from a local consignement shop. I love the way they look but I had to build landing pads as you can see
Dean in Ct.
Images: 32
Postby Roo Dog » Thu Mar 28, 2013 4:56 pm
Martin,
Plastic garden gate hinges from our local hardware.
Sprung loaded with adjustment.
No problems so far and they have had some use.
RD
100_1740 (500x333).jpg (156.95 KiB) Viewed 5288 times
100_1737 (800x533) (500x333).jpg (213.51 KiB) Viewed 5288 times
Lets do a three sixty and get out of here !
Roo Dog
Postby Woodbutcher » Thu Mar 28, 2013 6:02 pm
I don't have a close up picture but you can still see what they look like. Made of Stainless steel and from a Marine parts supplier. Surprisingly cheap, and good quality.
http://www.marine-products.com/parts/bo ... inges.html
Woodbutcher
Postby 48Rob » Thu Mar 28, 2013 6:22 pm
Martin,
Piano hinges don't look so cheap if they are installed like a regular hinge, so you only see the backbone of the hinge.
Like this;
Rob
48Rob
Postby halfdome, Danny » Sat Mar 30, 2013 10:48 pm
Like 48Rob said :thumbsup: .
I use preformed aluminum piano hinges from Grant Whipp.
They look and work quite well.
Hardly noticeable on the outside when installed.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Roo Dog » Sun Mar 31, 2013 6:05 am
Closer picture of the gate hinge.
Take it easy
RD
Roo Dog
Postby H.A. » Sun Mar 31, 2013 6:16 pm
I used this plated brass hinge at McMaster-Carr. Its the type "4" on this page.
http://www.mcmaster.com/#lift-off-hinges/=m4fuui
They have gone up in cost over the past few years, About 6$ when I purchased !
I am a real fan of liftoff hinges for just about everything,
In fact as a Kid I did not realise there was anything but that as all houses are built with lift-offs.
Then arrived in America, Some things here are "different".
H.A.
Postby DMcCam » Mon Apr 01, 2013 10:51 pm
Hi Martin, We used these refrigerator door hinges. Here's a link: http://www.etrailer.com/Enclosed-Trailer-Parts/Redline/383700.html
They are flush fit so we need to offset them.
Here's a picture of the offset aluminum.
Cheers,
Dave
DMcCam
Postby working on it » Thu Apr 04, 2013 9:08 pm
Stanley gate hinges (or the HD generic copy), powder coat black, with plastic bearing surfaces. About $6 each. I used three per door so they'll never sag.97338
173193172890148599
working on it
Images: 457
Postby markhusbands » Mon Apr 08, 2013 1:27 pm
I'm going to use the offset piano hinges I think.
133923
markhusbands
Images: 58
Postby GerryS » Mon Apr 08, 2013 4:23 pm
Check out camp-inn. They will sell parts to builders....I believe. Their hinges look really nice!
GerryS
Postby SamIAm » Tue May 07, 2013 12:48 pm
For a clean look, you could go with a SOSS hinge, which is invisible from inside and outside, being set within a mortise in the door and frame. Expensive, though.
Brendon
http://www.leevalley.com/en/Hardware/pa ... at=3,41241
SamIAm
Postby jss06 » Tue May 07, 2013 7:06 pm
working on it wrote:Stanley gate hinges (or the HD generic copy), powder coat black, with plastic bearing surfaces. About $6 each. I used three per door so they'll never sag.97338
I use these as well. I only used 2/door but I don't think it will be an issue.
jss06
Palladium Donating Member
