SLOW! your transportation problems have been solved!
Re: SLOW! your transportation problems have been solved!
Postby Fenlason » Tue Mar 26, 2013 6:06 am
Back in the 80s someone was building a much smaller similar vehicle. They were not putting them into production, but put together a book so that others could build them. This one had the engine in the rear, and was driven by the singular rear wheel.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Postby Mojave Bob » Tue Mar 26, 2013 7:13 am
Fenlason wrote:Back in the 80s someone was building a much smaller similar vehicle. They were not putting them into production, but put together a book so that others could build them. This one had the engine in the rear, and was driven by the singular rear wheel.
Are you thinking of the Tri-Magnum? http://blog.modernmechanix.com/the-mi-urbasport-tri-magnum-home-built-excitement/ I have a full set of plans for this somewhere. It was pretty tempting to build one. However, as designed, it lacks heat, air conditioning (or even decent ventilation) or a reverse gear. So, lotsa fun but not too practical.
Mojave Bob
Images: 46
Postby Fenlason » Tue Mar 26, 2013 8:03 am
No that wasn't it. hmm the one I have [somewhere] was much smaller. It was a single person vehicle, pretty low. You entered it from the top. To make it more visible in traffic is had a raised portion in the rear. the best way I can describe it, is sort of like the tail fin on a plane.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Tue Mar 26, 2013 8:06 am
I just found a photo :banana:
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Tue Mar 26, 2013 8:19 am
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby dustboy » Thu Mar 28, 2013 2:27 pm
"Only $6,800
It only costs $6,800. That’s about what you would pay for an outboard motor to power a rowboat."
WHAAAAT? That kind of money should get you one FAST rowboat.
dustboy
Images: 10
Postby Kevin A » Thu Mar 28, 2013 9:19 pm
Kevin A
The other guy
Images: 289
