Easy way to lock a hatch in the up position with gas shocks
Postby Kharn » Fri Mar 29, 2013 7:54 am
If you're using gas shocks that just assist with lifting the hatch, or aren't strong enough to hold it up in all circumstances (wind, snow, whatever), I saw a simple way to lock one side in the extended position without needing a separate prop mechanism:
Find a piece of metal tube that is sized to slide easily over the body of the shock, length 1" greater than the minimum rod extension you want to maintain. Cut halfway through the tube at the desired rod extension length, and remove 180 degrees of the tube wall, leaving a lip that extends 1" beyond your desired extension length. Drill a hole through the tube so a locking pin with wire retainer (like McMaster's 98416A211) can go through both sides of the tube (the tube also needs to be large enough in diameter to accomodate the retaining pin and the rod at the same time, the pin should be near the top of the tube).
The idea is when the shock is extended, the retaining pin traps the rod to one side of the tube, so the shock will rest on the tube wall when under load, thus holding your hatch up. To close, remove the pin, lift up on the hatch a bit, center the tube on the shock (simply push the tube so the 1" lip is against the shock's body) and then lower the hatch. When opening the hatch the tube will tip to the side, blocking the shock so you can insert the retaining pin without having to support the hatch with your other hand.
I'll post a CAD drawing tonight to better illustrate the concept.
Kharn
Re: Easy way to lock a hatch in the up position with gas sho
Postby Kharn » Fri Mar 29, 2013 4:20 pm
This should make it a little more obvious:
103798
Kharn
Postby CarlLaFong » Fri Mar 29, 2013 9:12 pm
Glad you posted a pic. You lost me at "Find" :lol:
Very simple and clever solution
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby Dale M. » Fri Mar 29, 2013 9:49 pm
Simple "hitch pin clip" would also work well for the pin concept...
Dale
Dale M.
Images: 18
Postby AlgoDan » Sat Mar 30, 2013 5:48 am
I like your idea, very simple add-on, you could also use PVC pipe. The PVC would keep the shock from getting scratched up. Good idea :thumbsup:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby Kharn » Sat Mar 30, 2013 6:33 am
Dale M. wrote:Simple "hitch pin clip" would also work well for the pin concept...
Dale
I'm not sure if you could find one large enough with a low enough retention force to make it easy to use. The wire retainer is quite easy to remove, but another option would be a push button quick release pin.
Kharn
Postby eamarquardt » Sat Mar 30, 2013 10:10 am
CarlLaFong wrote:Glad you posted a pic. You lost me at "Find" :lol:
I made it past the "find" but then got lost. The pic clears it up.
Thx.
Gus
eamarquardt
Images: 150
Postby Dale M. » Sat Mar 30, 2013 1:34 pm
Dale
I may have misspoken calling them "hitch pins"... The are "reuseable cotter pins"....
They come in maybe 15-20 sizes and maybe 3-5 different spring "tensions"... Use them quite a bit on my garden tractor and and many "property" and misc projects.....
http://www.mcmaster.com/#cotter-pins/=m3ugot
Dale
Dale M.
Images: 18
