A cargo conversion ... Just starting!
Postby kkayv » Mon Mar 25, 2013 11:21 pm
I got my 6x12 cargo mate and I'm going to make it into a moto trailer!
Pics to come soon.
kkayv
Re: A cargo conversion ... Just starting!
Postby roadinspector » Mon Mar 25, 2013 11:24 pm
WELCOME!! :thumbsup:
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby kkayv » Tue Mar 26, 2013 4:14 pm
Here is the trailer right after I got it!
kkayv
Postby kkayv » Tue Mar 26, 2013 4:17 pm
Just getting started.
Here I did some primer on the walls. I had to stop tho cuz we were getting snow and cold. :frightened:
I am gonna prime the walls and do a grey color with some silver metalic paint mixed in. A gal has to have a little "bling" in her trailer. :D
kkayv
Postby kkayv » Tue Mar 26, 2013 4:19 pm
Snap together garage flooring will be used in a coin pattern.
Snap together coin flooring in gray.
kkayv
Postby pvangel » Tue Mar 26, 2013 5:27 pm
Nice flooring!!!! :applause:
pvangel
Postby revorunner » Tue Mar 26, 2013 7:06 pm
Looking forward to your build. :thumbsup:
revorunner
Postby pappaw » Wed Mar 27, 2013 9:00 am
Purdy :thumbsup:
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Postby kkayv » Thu Mar 28, 2013 12:25 pm
wow! You packed a lot into that little trailer! Impressive!
:D
kkayv
Postby kkayv » Thu Mar 28, 2013 12:31 pm
Boxes are starting to come to the door with stuff for the trailer! Counter top and cabinets should be ready to pick up today. Then I gotta paint them. They were cheaper that way- plus I wanted my own color choice. The 3" memory foam topper I will cut and use for two fold down beds is here too. I also orderd vinyl in balck and grey. I plan to cover the foam with grey vinyl with a black stripe down the middle length wise. I am going to paint a table and chairs in the same color scheme. Should look sharp! Also gonna make a curtain for under the sink with the vinyl. I have A LOT of work to do!!! :?
kkayv
Postby SoCalCTCamper » Thu Mar 28, 2013 2:38 pm
Welcome to the group...good looking trailer...look forward to more pics
SoCalCTCamper
Looking for other CTers in the Inland Empire area
SoCalCTCamper
Postby kkayv » Tue Apr 02, 2013 9:21 am
Well...
Trailer is pretty much painted. I wanna do one more coat today but prob can't get to it till later this week. Gotta work late tonight. :(
I have to say that I really dislike the "trim" that trailer companies use to cover the seems in the plywood walls. It's cheap, ugly and breaks easily. I may eventulaly rip it down and put some better trim pieces up. But,,,, so much to do now.
kkayv
Postby kkayv » Tue Apr 02, 2013 10:24 am
Here is the vinyl I will be using to cover the foam for the beds. I can't hardly believe how well it matches the flooring and paint! :D
vinyl for beds
kkayv
Postby kkayv » Wed Apr 03, 2013 2:23 pm
So things are a bit delayed. As usual with any construction...things are more complicated than previously thought. So- still painting and have to do the floor first. Not sure how I'm gonna match the curve in the front of the trailer on floor. I will attempt to make a template out of paper, cut it and then trace that edge onto the flooring and cut.... Hope I don't have to say too many curse words in the process! :?
kkayv
Postby kkayv » Mon Apr 08, 2013 11:58 pm
New Pics of progress. I got some professional help from a friend for work on the window, floor, and cutting floor for recessed pop up wheel chocks! So stoked! I also painted the walls! Finally making some progress@! :)
Why the BLEEEP does this website flip my photos that are facing the right way????
kkayv
