My build of Benroy Style Trailer
Re: My build of Benroy Style Trailer
Postby AlgoDan » Sun Mar 31, 2013 5:37 am
Yesterday was a slow day, I pre-drilled all the hole in the roof edge mldg and cut to length. Today I plan on laying down the aluminum on the roof, I will just use a sealant on the outer edges and a few temporary screws while it sets up...
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby AlgoDan » Sun Mar 31, 2013 5:54 pm
Ok Happy Easter to all, I did get the roof laid down with sealant and temporary screws. The sealant will set up within 24-48hrs. So this week I will get the end caps powder coated and final welding of the tongue and A-Frame braces.
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Tue Apr 02, 2013 4:54 am
Today I will work on hooking up my 12volt wiring to fixtures/switches and outlets. Then move on to securing the roof vent in place. I will try to check off the list as each day passes, I hope.
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Apr 03, 2013 3:31 pm
Ok got the Roof vent installed and caulked. Also most of the 12volt wiring hooked up...
104122
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Wed Apr 03, 2013 3:36 pm
Smoke 'em if you got 'em!
(i.e. Cooking right along.) :thumbsup:
Postby AlgoDan » Wed Apr 03, 2013 3:54 pm
lol, Thanks KC. Trying to get er! done....I can smell the fire now...
KCStudly wrote:Smoke 'em if you got 'em!
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Apr 03, 2013 6:31 pm
Alright now time to connect up to switch panel....need to get more wire connectors, ran short. Also need to re-label switches
104123
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Thu Apr 04, 2013 2:52 pm
Ok the final welding of the A-frame and tongue are complete. I need to run the wires through the frame, mount the coupler, hang the suspension and locate the axle....still waiting for wheels and fenders.
Rodney laying a bead down...
104178
104179
104180
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Thu Apr 04, 2013 3:01 pm
Slick! :thumbsup:
Any reason why you didn't extend the 'A' part of the tongue out further?
Postby AlgoDan » Thu Apr 04, 2013 4:17 pm
I only wanted it out enough for a storage box on the front, with 1/4'' thick tongue and 3/16''thick A -frame its a plenty. I figure when done the dry weight should come in at 600lbs./900lbs loaded.approx.
KCStudly wrote:Slick! :thumbsup:
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Thu Apr 04, 2013 4:28 pm
I bilge after I pull anchor...lol, getting new labels made up.
biziedizie wrote:
AlgoDan wrote:Alright now time to connect up to switch panel....need to get more wire connectors, ran short. Also need to re-label switches
104123
So do you use the anchor and bilge pump switches much :FNP :lol: :lol:
Build Journal
AlgoDan
Images: 238
Postby Junkboy999 » Thu Apr 04, 2013 7:04 pm
Looking good
I’m just wondering if you’re really gonna need an anchor or bilge pump. :?
:lol: Ha hahah
Junkboy999
Images: 52
Postby AlgoDan » Thu Apr 04, 2013 7:55 pm
Yes in case I wander into the lake, maybe a paddle too. lol...
Junkboy999 wrote:Looking good
:lol: Ha hahah
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Fri Apr 05, 2013 1:45 pm
Ok today was finalize the 12 volt hook-up. Then start the 110 volt input, galley outlet and outdoor outlet and will do a cabin outlet also..
Power in and locate outlet box for the galley side
104226
Galley side test wiring
104227
Test both Galley and Outdoor outlets..
104228
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Fri Apr 05, 2013 4:23 pm
Ok connection made on a couple outlets and inlet
Power Inlet
104231
Outdoor outlet
104233
Under cabinet outlet
104232
Build Journal
AlgoDan
Images: 238
