This is the frame I am starting with. I just need to finish sanding & painting and I will start construction. I change the tongue to 2.5 x 2.5 x .120 square tube, extended it by 12" & welded in the Jack mount. I also cut the spindles out of the original "U" channel axle and welded & bolted the spindles into 1.5 x 1.5 x .188 square tube. I also widened the axle by 2" just in case I deside to change hub & wheels.
Just a word to the wise, don't try to drill thru axle spindles unless you have access to a machine shop. They are very hard
The jack is a HF $13.99 2000# special. It can swing away or be removed. The kind wth the wheel was 1" too long.
I have started stockpiling my electrical pieces. I plan on picking up lumber & wire this weekend. The MDO for the sides will have to wait a few weeks.
