Can i flip my ramp???
Postby pitbullluvajrod » Thu Apr 04, 2013 8:11 pm
Hello everyone, how are y'all doin? My question today is... has anyone flipped there ramp on their cargo, or is it even a mod that can be done? This is something I'm thinking would be handy. Any thoughts are greatly appreciated.
pitbullluvajrod
Re: Can i flip my ramp???
Postby roadinspector » Thu Apr 04, 2013 8:32 pm
Anything is possible. I speculate that you are thinking about moving the hinge point to the top. The main problem I would think of is the weight. The ramp is heavy. It is constructed to support a the weight of just about anything you can fit in the door. I would hate to have to lift it up. If you rebuilt the frame out of something light weight like alluminum would make it more do-able.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby pitbullluvajrod » Thu Apr 04, 2013 9:06 pm
That was my thought as well. I figured I would have to put the ramp on a serious weight loss program. My other thought was a 3way barn door, like the rear of an Astro van. Top lifts, bottom swings on each side. The issue with that is latches. :thinking: I want to start from the galley forward, Is that a mistake? Thanks for any opinions.
pitbullluvajrod
Postby crumvoc » Thu Apr 04, 2013 10:26 pm
I've pondered a little different idea. How about completely replacing the rear doors, whether ramp or barn, with a non-opening rear wall. The reason is to make of so that I can fit it with either a rear rv door or a very large window. I envision a lightweight aluminum framed wall with a flange to seal it around the edges. Just thinking.
Living in the high-desert.
crumvoc
Images: 139
Postby roadinspector » Fri Apr 05, 2013 11:00 am
Thats the beauty of all this. Its your toy! Play with it how you want. As long as its structurally sound GO FOR IT!! I have seen the wall done before and it worked great for them. Have not seen the converted reverse split multi-swing ramp though. Sounds interesting. It should work fine. There are many different ways to latch it. Just off the top of my head I would lean towards drop pins like on cattle trailers.
roadinspector
Images: 127
Postby dustboy » Fri Apr 05, 2013 11:00 am
It's a pretty good idea if you don't need the ramp--once you flip it up it is an instant awning!
I built this truck a few years back, and the overhead door was awesome. You can't see it in this photo, but the truck has a galley that pulls out underneath the bed. We could pull up to a campsite in the rain and be cooking in minutes.
dustboy
Images: 10
Postby pitbullluvajrod » Fri Apr 05, 2013 12:57 pm
Thanks, guys... I appreciate your opinions. In response to the use of the ramp, I have none. I've considered removing it completely and starting fresh. The idea was as you said, instant awning. The truck with the slide out is nice.. Again, I thank youfor the opinions.
pitbullluvajrod
