Another Ebay find, PitPosse makes it and was under $20. 4 self tapping screws into a frame member.
Mounted up!
It is a belted tire not a radial (all Tractor Supply had) but should be fine as a spare.
bc toys wrote:that much weight on those self tappers you better watch them close they will come out but good looking trailer and wish you the best on your trip
cleonard wrote:First I want to say thanky you for this thread documenting your build. I've been contemplating a slightly larger version and you have been a great source of information and inspiration.
It's been mentioned before, but how is your weight? Have you had a chance to weigh it loaded? I see that you managed to get four bikes in there and that has to be in the vicinity of 1000 pounds just in motorcycles. With the rest of the built it's got to be over 3000 pounds when loaded up to the max.
Most of the single axle trailes I've looked at were all rated at just under 3000 pounds. I know that over 3000 pounds in my state and you have to get electric brakes. A common axle rating is 3500 pounds and I'd bet that most use a 3500 pound axle but rate the trailer at under 3000 pounds to save the $$$ of electric brakes.
hankaye wrote:pvangel, Howdy;
Thought I'd heard a Homer Simpson "DHO-O-O-O-O-O-O-O-O"
behind a head-slap awhile ago.![]()
Glad to hear cooler heads prevailed and things are good to go!
hank
dustboy wrote:That's a tricky one--so it worked ok with all the loads running, but with just the lights on it blows?
And only the main fuse is blowing, not just the lighting circuit?
