Are there size requirements for the side marker lights?
Postby BoilermakerFan » Thu Sep 30, 2004 9:11 am
Does anyone know if there are size requirements for the side marker lights on trailers? I have some really cool Glass lenses that mount on industrial watertight indicating lights. The lights are about 1" in diameter and about 5/8" high. I can install either LED bulbs behind clear lenses or use incandescent bulbs behind colored lenses.
I live in Indiana and I'll check with my local DMV, but I thought I would post the question here too.
BoilermakerFan
Postby BoilermakerFan » Fri Oct 01, 2004 8:07 am
BoilermakerFan
Postby mikeschn » Fri Oct 01, 2004 8:48 am
I would probably buy a side marker light that was available at the auto parts store... and was actually labeled as a side marker light.
For example, many of these lights would work...
http://www.tjtrailers.com/store/clearan ... ights.html
The little light that you showed us in that link above, looks way too small.
Postby BoilermakerFan » Fri Oct 01, 2004 11:15 am
Mike
They are pretty small, but they are somewhat styled. Street rods have very small, bright turn lights and brake lights in many cases. I'm curious what the requirements are. Is it surface area based or simply a visibilty from a given distance? The visibility from a given distance is very easy to meet with high ouput LEDs or bulbs.
I noticed some really cool side markers on a tractor trailer than was really customized. They were pretty small ovals, about 2" long by 1" high with a glass-look lense and chrome surround. Might have to run a search for tractor trailer accessory lights on the web. :wink:
BoilermakerFan
Postby BoilermakerFan » Fri Oct 01, 2004 11:28 am
Found an interesting link:
http://www.truck-lite.com/webapp/wcs/stores/servlet/GenericView?pageName=/new/PressReleases_en_US/PressRelease17-MiniMarker.html&storeId=10001&langId=-1
Not sure how it applies to TDs, but I think it opens the door a bit for my quest for small marker lights!
BoilermakerFan
Postby mikeschn » Fri Oct 01, 2004 3:59 pm
I honestly don't think there is a requirement for the size... I don't even think anyone has visibility spec'd out...
When you go to the state/local police to have your trailer inspected they are going to give it a quick glance, and notice that you have sidelights, and move along to the next thing...
The key here is visibility... I think if you are reasonably visible from the side at night, then you're cool!
So pick your favorite side markers and go for it...
Postby Woody » Fri Oct 01, 2004 6:24 pm
I think that visibility is more important. In Florida on trucks it is a question of visibility in hundreds of feet I believe, size doesn't matter(when talking about lights) I will have to pull out the book and look.
Woody
Woody
E-mail: [email protected]
Woody
Images: 26
Postby Denny Unfried » Fri Oct 01, 2004 9:05 pm
Most all the clearance lights on the market are DOT approved but I have seen some installed backwards. Amber in the front and Red at the rear is correct.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Dan » Fri Oct 01, 2004 9:42 pm
Lights on trailers are a Federal requirement and the requirements can be obtained from the following link:
www.nhtsa.dot.gov/cars/rules/standards/ ... lrpstr.htm
However, I don't remember any requirement on size.
Dan
Dan
Images: 5
Postby BoilermakerFan » Fri Oct 01, 2004 10:33 pm
Thanks for the link Dan. I don't see a reference to size as you said, but they do reference the DOT approval that Denny mentioned. So, my cool lenses won't be acceptable for the side marker lights. I have found a few other styled lights and small bullet indicators. I think Painless has some side indicators as well.
I do have enough of them with red lenses to use in the galley area for low-level night lighting.
Last edited by BoilermakerFan on Fri Oct 01, 2004 10:50 pm, edited 1 time in total.
BoilermakerFan
Postby mikeschn » Fri Oct 01, 2004 10:35 pm
http://www.nhtsa.dot.gov/cars/rules/sta ... nspicuity/
The link two postings up wasn't working...
