I plan to cover my roof with canvas and tightbond 2. Then I am applying typical exterior house paint to the entire thing.
Irving wrote: I think that the plywood sides will be just fine with primer and paint on the bare wood.
doug hodder wrote:Irving wrote: I think that the plywood sides will be just fine with primer and paint on the bare wood.
Sounds like a gamblin' man....
Roo Dog wrote:Irving,
We used a plastic moulding supplied by a caravan parts supplier.
Easy to bend.
RD
Irving wrote:Are you suggesting that water will penetrate through several coats of exterior primer and paint?
doug hodder wrote:Irving wrote:Are you suggesting that water will penetrate through several coats of exterior primer and paint?
There have been a number of them over the years here that have had that problem. Doug
desertmoose wrote:If you are going to canvas the roof, I'd go ahead and canvas the sides also. That's what we did, so no molding is required.
We are very happy with the canvas and house paint approach.
Take a look at our build journal for more pics.
viewtopic.php?f=50&t=45718
Sam
mezmo wrote:After seeing a lot of posts over time here on the forum on
the topic of only using primer and paint on a plywood, the
general take on that topic, that I have gained, is that there
are multiple things affecting it. The quality of the plywood,
the type of the plywood and the wood species used etc., is it
stressed - i.e. bent ?, what weather is it exposed to ? in use
and in storage... There is also a continuing maintenance need
with it as well.
The main culprit seems to be movement in/of the wood itself
from normal temperature expansion and contraction and such.
It can be enough to break/crack the paint surface and thus invite
problems with water. One reasonable approach to obviating
the problem is the old-tech glue-canvas-paint/paint-canvas-paint
technique. It has worked on waterproofing wooden boats, and
it has worked on old-time TTs. It's not totally maintenance free,
but is much moreso than just paint alone.
