by working on it » Thu Apr 18, 2013 9:39 pm
As I said in my previous post, I went newfangled instead of vintage, and bought a new Dual-Fuel Coleman. The advantage of having a reserve fuel source was the kicker. The stove I recently bought is also Dual-Fuel. I went to Cabela's to examine the one like PubUltraStar bought, and also the Northstar with pushbutton start. I decided on the Northstar for four reasons: (1) instant start (for my wife's benefit, though I made sure that it could also be lit with a match), (2) protective wire cage around the globe (I broke two globes on my original lantern, back in the 60's), (3) the price of $90 on sale (25% off normal), and (4) it is Coleman green.
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
