The SQUARESTREAM
Re: The SQUARESTREAM
Postby Tahoe Neil » Fri Jan 18, 2013 1:30 am
Here is a series of photos that show my completed upper cabinets, cabinet doors, trim, and other stuff.
I still have drawers to make along with a large over bed cabinet. (Plus a 100 other things I havent thought of.)http://www.tnttt.com/posting.php?mode=reply&f=42&t=50275#
My youngest traveling buddy.
The back open. The bed is split in the middle, each half folding up against the two walls. The pedestal in the middle is free standing and moves aside so I can load trikes, bikes, Moto bikes, paddle boards.....etc.
Upper cabinet. Shiny Aluminum ceiling. Repurposed Aluminum coat hook
True Ice box (they never break down). Modern Microwave.
Front bench seat. I want to make a small pedestal table in this corner. Something to put up and take down on demand
Kitchen. SMEV two burner cook top with sink covered by cutting board. 12v on demand faucet. Under the sink you can see where I am keeping my fresh water, in a 5 gallon tank. Next to it, under the sink drain is another 5 gallon tank for grey water. Small tanks for small use (no shower/privy) Light weight. In the right hand cabinet is a portable Thetford toilet. It is also accessible from an exterior cargo door.
Switch on the left is power to sink pump. 110v receptacle, 12 volt receptacle. 1950's style "boomerang" formical top.
Dresser and boxes for nicks, nacks, books and maps. You can see the spare tire which will eventually have a home in a "to be built" steel reinforced cabinet above the bed.
The reading light on the wall next to the bed is a high intensity LED light on a flexible neck. Works real nice. I have GOT to clean up that paneling edge with molding.
posting.php?mode=reply&f=42&t=50275# TIME TO GO CAMPING!!! posting.php?mode=reply&f=42&t=50275#
Neil
Tahoe Neil
Images: 52
Postby KevinC » Fri Jan 18, 2013 4:52 am
Very nice work! I like the name too.
The trike is really cool too. I have never seen anything like that. Is that a thing that a lot of people build or is that all your idea?
Subscribe FREE at:http://www.cooltears.com
KevinC
Postby Tahoe Neil » Fri Jan 18, 2013 11:17 am
Thanks Kevin,
The trike is just a crazy idea I had. Some friends and I have been cutting up bikes and welding them together as trikes for a few years. This one is the first we made to look more like a car/truck. The design for the frame and axle came from the good people at atomiczombie.com. They are THE source for crazy bike designs that anyone with a welder can turn into working bikes and trikes. The frame was fabricated mostly from 1.5 inch EMT tubing along with tubing from old steel bikes. Go kart parts were used for brakes, rear chain, axle and sprockets. Bike parts for gears, pedals, front chain, head tube, shifter etc.
The front wheel hub is a 2 kilowatt, 48 volt electric motor. It is powered by 4 sealed lead acid batteries stored behind the seat. Electric assist range is up to 8 miles. Motors available range from .5 kw to 2.5 kw. Complete motor/controller/battery packages range from $700 to $2000 (and higher for LiPO4 batteries) They are marketed and designed for use on standard bicycles. We have seen only a handful of BIG trikes like ours around.
An interesting note: as long as a trike has 3 wheels, pedal drive, and goes no faster than 20mph, it is LEGALLY a bicycle. Even my 9 foot long, 300 lb monster is a bicycle.
Tahoe Neil
Images: 52
Postby OverTheTopCargoTrailer » Fri Jan 18, 2013 12:49 pm
Niel
You could make a fortune selling those to Drunk drivers.....who lost their license & cars :D :D
If they need to pay $10,000 on legal fees, surely they will have a few G's left over for your bike.
You can make smaller wheels & fiberglass body...
besides in the city you normally only average 25 MPH anyway.
I sent you e mail , hopefully I can catch up with you next week Wed.
Jerry
Postby bdosborn » Fri Jan 18, 2013 7:40 pm
Wow, that's a really cool trailer. It looks like you could move in and live there for awhile. :thumbsup:
Images: 806
Postby sportxlh » Sat Jan 19, 2013 3:56 pm
The trailer turned out great: very inspirational! The trike is pretty too!
sportxlh
Postby mezmo » Sun Jan 20, 2013 2:26 am
Great Design and Execution !
I love the light wood used, frame-and-panel cabinet doors
and the metal edge trims.
This one goes in the "Use for inspiration" category !
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby adamhusband » Thu Mar 28, 2013 9:57 pm
Beautiful build on your trailer. A lot of craftsmanship went in to this build. My conversion will be more simple and smaller but I love what you did with it. I could live in that beautiful trailer and be very comfortable. Well done!!!!
Adam
101137
adamhusband
Images: 47
Postby hankaye » Thu Mar 28, 2013 11:38 pm
Tahoe Neil, Howdy;
Keep meaning to ask ... do you have a link for where we might find an icebox
such as the one you are touting ???
hank
hankaye
Postby dustboy » Fri Mar 29, 2013 12:04 am
hankaye wrote:Tahoe Neil, Howdy;
hank
Yeah, I second that. I remember my folks had one in our old VW microbus pop-top. They just made a big block of ice (as I do for our cooler) and we were good for several days.
dustboy
Images: 10
Postby Woodbutcher » Fri Mar 29, 2013 9:26 am
Great job!! You done good! :applause:
Woodbutcher
Postby Tahoe Neil » Sun Mar 31, 2013 2:03 pm
Hank and DustBoy,
I got the ice box at Vintage Trailer Supply
http://www.vintagetrailersupply.com/Ice ... ts-810.htm
Mine's the larger of two they sell. $160
Neil
Tahoe Neil
Images: 52
Re:AC installation thru back door
Postby pmspirito » Sat Apr 06, 2013 5:20 pm
WOW beautiful workmanship. I understand your AC installation. What does it look on the inside. Is there a shelf attached to the inside of the door. What happens when it rains, what seals around the removable AC. I would appreciate some more photos.
I built Thetrailershowroom 7x14. Its complete except for the AC. Right now I plan to mount it permanently thru the back cargo door. But I am concerned about the weight on the door. I sure could use some advice.
see my cargo trailer build at viewtopic.php?t=45197
Peter Spirito
www.peterspirito.com
pmspirito
Images: 112
Postby S. Heisley » Sat Apr 06, 2013 5:42 pm
Honestly, I think your's is the nicest CT conversion that I've ever seen. :o
...Very nice job. :applause:
Postby Tahoe Neil » Mon Apr 15, 2013 12:30 pm
pmspirito,
Sorry its taken so long to reply to your question. The trailer was in winter storage up until last week. I took some closeup pics to help show the story of the air conditioner.
1. The door has taken the weight of the unit fine. No sign of sag or fatigue. However, not all trailer doors are created equal. If there is a week link in CT doors, I think it would be a light weight hinge. The sheer strength of most door panels is high.
I did NOT take the door apart and put in extra steel (like some have). I slipped 3/4 x 4 pine between the inner and outer panels, surrounding the cut out hole, then glued and screwed them into place. The door was then inserted and screwed to the pine.
95143
2. My door was the perfect fit for my air unit. This was critical when it came to how I "mounted" the unit.
3. The unit it "mounted" using only the force of gravity. Here is how
95141
4. I screwed a 1 1/4 inch aluminum angel iron piece to the top of the unit
104759
5. The unit is lifted into place, with the top slipped in first, so the aluminum piece sits just inside the door frame.
104758
6. The bottom of the unit rests on the bottom of the door frame. Fortunately the bottom of the unit face has a "step" so that, in this position, it abuts the door frame. This keeps the bottom of the unit from moving into the trailer.
104757
7. With the unit in place, the unit's weight is cantilevered off the back of the door. Pressure pushes the top aluminum L bracket against the top of the door frame. Pressure pushes the unit's bottom "step" against the bottom of the door frame. After its in place, I place a strip of foam on each side to seal things up.
104758
Where I travel, if its raining its cold and the unit is either at home or stored under my bed.
Ive had no leakage problems.
Around here, dust is a bigger challenge. With the sides sealed with foam, Ive had no dust get in, even during the WORST of storms.
The door is handling the torque of the mount, showing no signs of deformation, stress or bending.
The only draw back I see is if someone moves often; Lifting the unit in and out is kind of a pain.
While moving the unit around, I duct tape a piece of 1/4 plywood to the back of the unit so as to not dent the cooling fins.
I only mount the unit while camped. I never leave it there while "on the road".
Most of the time I leave the unit at home because its not that hot where Im going. Leaving it in while on the road could be a problem if it experienced a large dynamic load (bump) causing a lot of torque on the door.
I think someone could permanently mount their unit to their back door this way with a couple modifications. Of course you would screw the top and bottom of the unit to the frame around the hole. Then in order to mitigate the torque of dynamic loading, you could add diagonal bracing from the back of the unit to the door. The unit's exterior frame should be robust enough so that you don't have to add a shelf.
Keep in mind the strength of your door comes from its hinges and from the sheer strength of your exterior and interior skins. My door had NO steel vertical studs (like the walls). Instead, the door skins were screwed to horizontal 3/4 x 4 inch pine strips between the skins. If you felt you needed to increase the sheer strength of your door, you could get in there and add more pine along with adding more screws. (When building a house here in earthquake country, they call for more screws per inch along plywood sheer walls)
Ive enjoyed watching your build pmspirito,
Cheers,
Neil
Tahoe Neil
Images: 52
