can I paint a plated swing away jack?
Postby surveytech » Mon Apr 10, 2006 6:20 am
I am wondering if anyone has any suggestions on how to paint a swing away jack that looks to be zinc plated. I am concerned that any paint I apply will wind up chipping away because of the zinc plating. Obviously some sort of primer would be a good thing but not sure what to use.
Ultimately I would like to paint the jack with the same paint on the trailer frame which is Rustoleum black hammered enamel. I have both spray and brush on hand right now.
Has anyone done this successfully?
Or should I just leave it alone and live with the zinc plating.
Thanks!
Walter
surveytech
Images: 6
Postby Chris C » Mon Apr 10, 2006 9:06 am
Oops! :oops: Double post!
Chris :D
Chris C
Postby Chris C » Mon Apr 10, 2006 9:07 am
Give it some "tooth" by roughing it with sandpaper and prime it well with a primer designed to go over zinc. Then you should be able to paint over it.
Chris :D
Chris C
Postby Bandit » Mon Apr 10, 2006 10:06 am
I did the same thing. All you need to do is scuff them up and paint with only the Hammerite paint. The Rustoleum does not need a primer.
This photo is before I painted, I used the Rustoleum Hammerite Green paint.
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby SteveH » Mon Apr 10, 2006 10:35 am
Walter,
Are you sure it's zinc plated? Normally hitch parts are cadmium plated witch is much easier to get paint to stick to...basically, just prime and paint.
SteveH
SteveH
Images: 42
Postby surveytech » Mon Apr 10, 2006 10:50 am
SteveH wrote:Walter,
Steve,
No, not sure at all. It is plated but with what I dont know. I assumed (I know, never assume) that since its all shiny it was zinc plated.
It could be cad plated but I cant tell the difference. Is there a way?
Purchased the jack at Harbor Freight.
Thanks for the help.
Walter
surveytech
Images: 6
Postby SteveH » Mon Apr 10, 2006 11:55 am
Walter,
Zinc, or galvanizing is usually dull, or will soon dull, and soft. Galvanizing is also usually rough surface, while cadmium plating is smooth surfaced, and harder. I would wager you have cadmium plating as it is a lot cheaper for the manufacturer. I would scatch it with a Scotchbrite pad and prime and paint.
SteveH
SteveH
Images: 42
Postby surveytech » Mon Apr 10, 2006 12:55 pm
Steve,
It sounds like its cad plated to me. This sure isnt dull like galvanized. Its shiny.
Thanks for the heads up. I would have never thought about Cadmium plated stuff.
Learn something new everyday here. way cool.
Thanks Steve!
surveytech
Images: 6
Users browsing this forum: Moto_marco and 4 guests
