How critical is ball height?
Postby hwitten » Mon Apr 15, 2013 4:46 pm
Manufacturer gave me 16-17 inches to top of ball. I'm at 17 1/2 inches with my supplied receiver (2 inch).
Is that acceptable or do I go shopping for one with an inch less drop. Will be towing dry weight of 800-900 lbs.
hwitten
Re: How critical is ball height?
Postby CarlLaFong » Mon Apr 15, 2013 5:05 pm
This could be taken the wrong way, but 1/2" of ball height is not enough to worry about
Unless you're a hurdler :D
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby suckerpunched » Mon Apr 15, 2013 8:16 pm
depends on how long your legs are.......sorry,,,,don't give me any oppurtunities....can't resist
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby hwitten » Tue Apr 16, 2013 7:05 am
I guess I did leave that wide open now didn't I :)
Thanks for the answer(s). I forgot about junk in tow vehicle so I'll probably be "just right".
Hopefully just one more package from eTrailer to finish my 5-->7 pin upgrade.
Heinz
hwitten
Postby pete42 » Tue Apr 16, 2013 2:54 pm
I would think with the weight of the trailer tongue pressing down the receivers trailer ball will be close to 17 inches high.
In my experience it is best to have a little nose down or near level when pulling a trailer the trailer seems to follow better
if you are pulling two axel trailers you most defiantly want it to ride level to far down or up will cause one set of the tires to
carry more of the weight than the other not a good condition.
pete42
Postby hwitten » Tue Apr 16, 2013 3:01 pm
Thanks everyone.
Seems like I'll be ok. I'll remeasure once I get all hooked up in Quebec.
hwitten
Postby sagebrush » Tue Apr 16, 2013 4:54 pm
If front of trailer is lower, you will get better fuel mileage as trailer is always going downhill :lol: :lol:
Will
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
Postby Steve_Cox » Tue Apr 16, 2013 5:08 pm
Tongue weight alone would probably bring down the height of the hitch ball a half inch. :thinking:
Steve_Cox
Images: 196
Postby Al in PA » Tue Apr 16, 2013 5:19 pm
Harbor Freight has drop hitches to lower your ball 2" - 4". Here's are links:
http://www.harborfreight.com/ball-mount ... 94901.html
http://www.harborfreight.com/ball-mount ... 94902.html
One of these should solve your problem.
Al in PA
Postby Steve_Cox » Tue Apr 16, 2013 5:43 pm
Al in PA wrote:Harbor Freight has drop hitches to lower your ball 2" - 4". Here's are links:
How would a 2" - 4" drop solve his problem? :dancing
Steve_Cox
Images: 196
Postby Al in PA » Tue Apr 16, 2013 5:55 pm
Steve, he seems concerned that his trailer is lower than the hitch on his tow vehicle. By using a drop ball mount, the trailer tongue should be level or slightly lower in the front. In this position, the trailer should be less likely to have sway problems.
Al in PA
Postby CarlLaFong » Tue Apr 16, 2013 6:10 pm
sagebrush wrote:If front of trailer is lower, you will get better fuel mileage as trailer is always going downhill :lol: :lol:
Will
You can also turn your baseball cap backwards and lean forward.
CarlLaFong
Images: 5
Postby hwitten » Tue Apr 16, 2013 6:12 pm
Thinking on this some more and re-reading I think my setup may actually be right on considering that I'm bound to have some junk (luggage) in the Santa Fe and tongue weight of 60-70 lbs may just bring it perfectly into the 16-17in range.
Thanks for bearing with me. Being an ex-MH'er this hitch, tow bar, tongue weight, electric brakes, etc. stuff is somewhat new to me. Up until I bought myself a trailer I thought all there was to it was to hitch the sucker up and go but I'm learning. :)
hwitten
Postby Fenlason » Tue Apr 16, 2013 6:21 pm
won't the boxers vs briefs question affect all this also :NC
:R :R
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Postby len19070 » Tue Apr 16, 2013 8:02 pm
1/2" high in the front equals about 1/8" lower in the rear.
By the time you load stuff up....
Your fine.
Of course you could ask Dr. Sheldon Cooper What the exact difference would be? if you want that kind of an answer. :lol: :lol:
Happy Trails
Len
len19070
Images: 24
