Corwin C wrote:The first thing when you have problems with your trailer lights is to check for a good, solid ground on both the tow vehicle and trailer. A partial or intermittent ground can create all kinds of gremlins which are really difficult to track down. When signals are dim or don't operate as expected the ground is usually the culprit.
Irving wrote:When the brakes are applied the running tail lights clearly get brighter. But what about when your blinker is on while you are braking?
absolutsnwbrdr wrote:Irving wrote:When the brakes are applied the running tail lights clearly get brighter. But what about when your blinker is on while you are braking?
When you're braking, then the turn signals flash OFF instead of flashing ON.
Out of curiosity... what year/model is the Toyota? Are you certain that your truck brake lights are separate from your turn signals?
Looks like the Hopkins 48895 isn't a powered converter box, which means you're just adding more lights to your truck's lighting circuits. This is probably why the lights look brighter with the truck running. Which could mean that your trailer lights are just underpowered because they are piggy-backing off of the trucks circuit. I would think that the truck should be able to handle it but I don't know. Just a thought.
Something is definitely not right though.
eamarquardt wrote:Why not install lights and wiring on the trailer to match the tow vehicle. I'm sure you could make it so that you'd be able to use it with a regular 4 wire vehicle and a 5 wire vehicle with a little thought and perhaps an extra plug/socket.
Go with the flow.
Cheers,
Gus
Irving wrote:eamarquardt wrote:Why not install lights and wiring on the trailer to match the tow vehicle. I'm sure you could make it so that you'd be able to use it with a regular 4 wire vehicle and a 5 wire vehicle with a little thought and perhaps an extra plug/socket.
Go with the flow.
Cheers,
Gus
I thought about that, but I'd like to be able to tow the trailer with more than one vehicle.
