7x16 V-nose
7x16 V-nose
Postby wtcreaux » Tue Feb 19, 2013 10:13 pm
After lurking, picking people's brains, and countless drawings for floor plans, I finally pulled the trigger.......a CargoCraft 7x16 (+2' V) with 6'6" ceiling. ....
102360
102362
102361
wtcreaux
Images: 211
Re: 7x16 V-nose office
Postby roadinspector » Tue Feb 19, 2013 10:14 pm
Nice CT! Have fun with your build.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby wtcreaux » Tue Feb 19, 2013 10:20 pm
1" tubular steel wall supports allowed for 1" insulation
1/2" plywood between roof and 1" tubular steel supports provided a space for insulation (only 18" wide to allow for roof slope)
102364102365
wtcreaux
Images: 211
Postby wtcreaux » Tue Feb 19, 2013 10:38 pm
Spacing filled with insulation......the roof has 1-1/2" on the edges and 2" in the middle. The walls have 1" insulation....
102367102368
wtcreaux
Images: 211
Postby jwhite » Tue Feb 19, 2013 10:42 pm
I see you have rear stabilizer jacks, they really make the trailer rock solid when your inside.
jwhite
Images: 46
Postby wtcreaux » Tue Feb 19, 2013 10:46 pm
Luan plywood attached to furring strips (ceiling) with Liquid nails and brads (air-nailer).
3 coats of white semi-gloss (molding towards front not present due to cabinets going in)
102369102370102371102372
wtcreaux
Images: 211
Postby wtcreaux » Tue Feb 19, 2013 10:49 pm
jwhite wrote:I see you have rear stabilizer jacks, they really make the trailer rock solid when your inside.
You are so right. Even with my dad and I working/walking in the back, the trailer didn't move........ :D
wtcreaux
Images: 211
Postby dustboy » Wed Feb 20, 2013 9:32 pm
My understanding was that the jacks were a safety feature for an unhitched trailer--too much weight in the back and the front is going UP! Then when everything falls out the back door, back DOWN it comes! BANG!
dustboy
Images: 10
Postby jwhite » Wed Feb 20, 2013 10:10 pm
I would have never thought to get them but the sales person reccomended them and they were on 50.00 extra so I had them put on,when I went to pick up the trailer we were walking around inside and I thought wow this is really shakey walking around.
After I got home I figured out that you let the front down as far as it will go then put the rear jacks down and then crank the front back up and it's rock solid = doesn't shake at all.
I guess if you can't have a trailer built you can get those sizzor jacks for a car at a junk yard but that would be a real pain to use every time.
67460
jwhite
Images: 46
Postby wtcreaux » Mon Mar 04, 2013 11:24 pm
Hardboard applied to walls. These are able to be wiped with 10% bleach and gave a nice color. Used Liquid Nails (get the LARGE), requiring 1.5 tubes per panel. The "furring strips" are actually plywood strips screwed into the gaps between panels to hold panel while adhesive dries......
102951
Pops holding up the hardboard....BEST PART OF THE PROJECT (spending time with Pops)
102953
The framing is in the front of the trailer.......the left enclosed side will be the electrical closet.......the right side is in the bathroom....
102952
Just another view of the electrical closet and bathroom (where waterless toilet will fit)
102954
wtcreaux
Images: 211
Postby wtcreaux » Tue Mar 19, 2013 9:31 pm
Progressive PD4000 Power Control Center
103416
Overhead cabinets with conduit carrying wire for rooftop AC
103414
Aluminum angle used for molding
103413
103415
wtcreaux
Images: 211
Postby wtcreaux » Wed Mar 27, 2013 9:20 pm
Used painter's tape along the bottom wall
103735
Rust-oleum Garage floor epoxy (water-based)
103734
learning how to sprinkle flakes
103733
results
103732103731
wtcreaux
Images: 211
Postby roadinspector » Wed Mar 27, 2013 10:16 pm
roadinspector
Images: 127
Re: 7x16 V-nose
Postby wtcreaux » Wed Apr 03, 2013 7:03 pm
Used E-track along the edges for a bed and a shorter section higher for a bunk
104140
Installed LED track lighting on the ceiling
104141
The light in the center is coming through a rooftop vent (on a cloudy day)
104143
The LED light is on the left (of the picture)
104142
wtcreaux
Images: 211
Re: 7x16 V-nose
Postby wtcreaux » Thu Apr 18, 2013 10:25 pm
Marine waterless toilet......
104946
The Chief engineer (Pops) and the CFO discussing the results......she had been VERY leery of what I was envisioning but Im slowly winning her to the dark side
104945
cabinets
104944
wtcreaux
Images: 211
Users browsing this forum: Bing [Bot] and 11 guests
