Simple Maryland 5 wide build
Re: Simple Maryland 5 wide build
Postby JTROBB » Fri Apr 12, 2013 5:22 pm
I managed to paint and pre-wire the trailer this week. Today I welded on the rear stabilizers and loaded the cabin onto the trailer. I probably should have waited for help with the cabin but I don't idle well.
I need to bolt down the cabin, finish the wiring, tongue box, AC, and install fantastick fan under the tear.
Jason
104625104632104630104629104628104627104626
JTROBB
Images: 132
Postby AlgoDan » Fri Apr 12, 2013 5:48 pm
Looking good and making quick progress, wont be long to first camp :beer:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby JTROBB » Fri Apr 12, 2013 6:24 pm
If it wasn't for the holes in the rear floor for the fantastic fan and the AC tonight would be first camp, in the backyard.
Jason
JTROBB
Images: 132
Postby JTROBB » Fri Apr 19, 2013 1:29 pm
I've gone from daily posts to weekly posts, things really slow down the closer you get to finishing. I wired the teardrop for AC and DC this week. I put a group 27 battery in a harbor freight tongue box along with a 15 amp 3 stage charger and my AC ingress for the trailer.I got the trailer weighed with everything but a spare tire (battery, charger, and AC) and it weighs 1040 LBS. I slept in it last night and found that the AC refused to work. Luckily it was nice enough to not need it. Today I pulled the AC and sure enough it refuses to cool and more than 5 degrees below ambient. I bought a new one and am in the process of getting it fitted.
Jason
104956104955104957104958104959
JTROBB
Images: 132
Postby AlgoDan » Fri Apr 19, 2013 1:51 pm
Lucky you, you got to sleep in yours. I will have to wait till next weekend. Good luck with the new AC. :beer:
Build Journal
AlgoDan
Images: 238
Postby JTROBB » Fri Apr 19, 2013 5:36 pm
I did realize I need curtains. I plan to purchase a single panel of blackout curtains cut in half and Velcro them up at the corners. Is this a possibility? Any other ideas as far as hanging curtains?
Jason
JTROBB
Images: 132
Postby Oldragbaggers » Sat Apr 20, 2013 7:07 am
Jason,
I am using vinyl curtain track. You can get it so that either mounts overhead to the ceiling or vertical on the walls. Very inexpensive and light.
http://www.sailrite.com/Curtain-Track-Vertical-Mount-Vinyl-48
and eyelet style curtain carriers that you just whip stitch onto the curtain panel. Couldn't be easier.
http://www.sailrite.com/Curtain-Carriers-Eyelet-Style
or you can get the carriers presewn into a tape and just sew the tape across the top of the curtain
http://www.sailrite.com/Sew-on-Tab-Tape
I've used this in boats and it's extremely simple to do.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby Kharn » Sat Apr 20, 2013 9:40 am
Becky,
Cool idea, how do you terminate the track so the curtains do not slide off the ends?
Kharn
Postby JTROBB » Sat Apr 20, 2013 9:00 pm
That is a great Idea!!! Solves the problem of the curtain being in the way when entering and exiting the vehicle. Just make sure there is enough track to push the whole curtain to the rear and out of the way of the door when the curtain is not in use. There is a sewing machine in the house but I have not seen it used in 15 years, I think I might be able to figure it out but I have no idea what a whip stitch is. Or is a whip stitch something I can do by hand with a needle and thread?
Jason
JTROBB
Images: 132
Postby KCStudly » Sat Apr 20, 2013 10:11 pm
IIRC, and my interpretation is correct, a whip stitch is where you wrap the edge of the fabric with hand stitching. In this case you would loop through the fabric edge, through the slide eyelet, then back through the fabric edge.
I am a little rusty on my home-economics training, so you may want to wait until someone else chimes in before taking my word for it. :thinking:
Postby JTROBB » Sun Apr 21, 2013 5:12 am
Here is what I found on a Google search. If this is it, it doesn't look too hard
Jason
105126
JTROBB
Images: 132
Postby Oldragbaggers » Sun Apr 21, 2013 6:31 am
Kharn wrote:Becky,
There are end stops for the curtain track, only 50 cents each.
http://www.sailrite.com/End-Stop-for-Curtain-Track
The track also comes in aluminum if you prefer that look.
All of the curtain track parts are at this link, and if you scroll to the bottom of the page there are several how-to videos you can watch.
http://search.sailrite.com/?freeText=curtain
Becky
Oldragbaggers
Images: 331
Postby JTROBB » Sun Apr 28, 2013 2:07 pm
Curtains are done. I just cut down a pair of cheap light blocking curtain panels from Target. I learned to use the sewing machine this week. It took longer to figure out how to thread it than to actually hem the curtains. Note for planning a build, put a solid piece of lumber just above the door to mount your curtain. I didn't and had to mount the curtain up near the roof where i had something substantial to screw to. This made it necessary to curve the track around the front radius to cover the window completely.
Jason
105572105571
JTROBB
Images: 132
Postby Kharn » Sun Apr 28, 2013 3:41 pm
Threading the machine is always a pain. On mine (my mom's old machine), there's a metal disk sticking out in the thread path. If you go on one side, everything works perfectly, if you go on the wrong side, you spend 20 minutes clearing thread from all sorts of mysterious parts of the machine. :x
Kharn
Postby JTROBB » Mon Jul 01, 2013 5:17 pm
loaded up and made a 2300mile trip with no issues other than a generator that was spewing gas while running. Think it may be a stuck float on the generator.
108966
JTROBB
Images: 132
