Has anyone used butyl tape between the frame and floor? I'd like to do this to keep water from collecting in this area. Any thoughts or input? Did you put anything in to seal between your frame and floor?
Thanks,
-Troy
48Rob wrote:I used a roofing product that has aluminum on one side and a rubbery tar on the other, with the sticky side down.
It keeps water from collecting between the wood and steel frame, and helps to keep the paint on the frame from rubbing off.
Users browsing this forum: Google [Bot] and 5 guests
