Another Harbor Freight build
Re: Another Harbor Freight build
Postby Melven » Fri Apr 19, 2013 9:37 pm
Here are my hatch supports and a couple tables I made. The tables sit next two each other so really if I want the table big its big and if I want it small its small. Made from TV trays and a teardrop table kit from ebay.
Melven
Postby Melven » Fri Apr 19, 2013 11:52 pm
I cannot wait to get rid of those stupid HF fenders.
Melven
Postby markhusbands » Sat Apr 20, 2013 8:13 am
Have you figured out what your mounting method is going to be for the round fenders?
I've put fender replacement (hate the HF fenders too) and matching fender, frame, and tongue box paint as a "maybe won't get to it in time for summer" item. I'm having a pretty hard time estimating how long it will take to do things like wiring and cabinet finishing.
133923
markhusbands
Images: 58
Postby Melven » Sun Apr 21, 2013 11:32 am
markhusbands wrote:Have you figured out what your mounting method is going to be for the round fenders?
The fenders I got are huge like you said. I will post a pic tomorrow. I am probably going to cut them down and reshape them. Also eventually buy bigger tires. It will either turn out awesome or it will be a 75 dollar lesson learned. Haha.
Melven
Postby markhusbands » Sun Apr 21, 2013 5:25 pm
Hope it works.
133923
markhusbands
Images: 58
Postby Melven » Mon Apr 22, 2013 6:12 pm
Here is what the Fenders I bought look like.
Melven
Postby Melven » Mon Apr 22, 2013 6:13 pm
Here is what they look like after I chopped them.
Melven
Postby Melven » Mon Apr 22, 2013 6:16 pm
Looks messy around the fender I know. They sealant I use is black. I will get it cleaned up and It will look good again. Also I will make some wood trim to go around the fenders. I like them.
Melven
Postby markhusbands » Tue Apr 23, 2013 10:38 am
You managed to squeeze a pretty good fit out of those things. And it looks like the door just clears them. And now you can use the HF ones for scrap.
133923
markhusbands
Images: 58
Postby Melven » Tue Apr 23, 2013 6:12 pm
markhusbands wrote:You managed to squeeze a pretty good fit out of those things. And it looks like the door just clears them. And now you can use the HF ones for scrap.
Yeah they look alot better then I had imagined. Got lucky. Also I have room for some real tires under them still :)
Melven
Postby markhusbands » Tue Apr 23, 2013 8:28 pm
Are you going to just put new wheels on or new axle also?
133923
markhusbands
Images: 58
Postby Melven » Tue Apr 23, 2013 10:05 pm
markhusbands wrote:Are you going to just put new wheels on or new axle also?
I am going to do bigger tires. If I have to get bigger wheels or different wheels I will but I don't really care so long as they don't look bad. I don't mind the red snowflake wheels as the are but the tires are pretty small and aren't rated for more then 55mph.
I didn't consider a different axle really. What would be the benefit of doing that would you think?
Melven
Postby markhusbands » Wed Apr 24, 2013 6:19 am
Load I suppose. But I am also not sure about the lug compatibility with larger wheels. Might be no problem. But I am pretty sure (could be wrong) that you'll have to go to a bigger wheel/tire combo.
133923
markhusbands
Images: 58
Postby Melven » Wed Apr 24, 2013 11:02 am
markhusbands wrote:Load I suppose. But I am also not sure about the lug compatibility with larger wheels. Might be no problem. But I am pretty sure (could be wrong) that you'll have to go to a bigger wheel/tire combo.
I suspect my jeep wheels will fit my trailer. I put one of my trailer wheels on my spare tire holder and it fit. If that is the case some 5x5.4 cheepo wheels will work!
Melven
Postby markhusbands » Wed Apr 24, 2013 11:28 am
Well all right then. Makes it simple.
133923
markhusbands
Images: 58
