Easy doorstop
Easy doorstop
Postby les45 » Tue Apr 09, 2013 11:50 am
This may not work for everybody, but it did for my situation. I found my manufactured doors banging my front clearance lights in the glass area of the doors on my first camping trip. I really didn't want to install a strap like some have done so I came up with this simple tennis ball doorstop. A stainless cup hook holds very tightly when screwed into a tennis ball. I didn't want any holes or hardware messing up the lines on the weekender so I drilled a small hole in the edge of the vinyl part of my edge trim all they way through to the wood. I then took a syringe and filled the hole with CPES until it overflowed and then stuck the cup hook into the hole. After the CPES dried, the cup hook pulled out easily and now it's just a matter of popping it in place when we go camping. I store the tennis balls in the galley cabinet when they are not in use.
les45
Images: 605
Re: Easy doorstop
Postby Oldragbaggers » Tue Apr 09, 2013 1:26 pm
I have been mulling over how to solve the same problem and that is a great solution, except that I don't have trim on the front of my trailer to hook onto. I wonder if the little hooks that have suction cups on them would work. Stick the hook into the tennis ball and then put the suction cup on the side of the trailer
:thinking: :thinking:
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Re: Easy doorstop
Postby absolutsnwbrdr » Tue Apr 09, 2013 1:32 pm
That tennis ball is a nice solution Les :thumbsup:
For a more "factory" approach, these baggage door catches are readily available and work very well too.
http://www.campingworld.com/shopping/item/squared-baggage-door-catch-stainless-steel/49563
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: Easy doorstop
Postby les45 » Tue Apr 09, 2013 1:35 pm
Oldragbaggers wrote:I have been mulling over how to solve the same problem and that is a great solution, except that I don't have trim on the front of my trailer to hook onto. I wonder if the little hooks that have suction cups on them would work. Stick the hook into the tennis ball and then put the suction cup on the side of the trailer
Suction cups would probably work or you might drill the hole in your door and let the ball hang from the door. It could also hang somewhere down around the latch handle or even near the bottom.
BTW - your build is really looking great. Have you camped yet?
les45
Images: 605
Re: Easy doorstop
Postby les45 » Tue Apr 09, 2013 1:39 pm
absolutsnwbrdr wrote:That tennis ball is a nice solution Les :thumbsup:
I considered those after some friends pointed them out on their popup. I just didn't want to add any more hardware to the outside lines. Also, the front clearance light is mounted on the side and keeps the door from coming close enough to the side to make them work without shimming them up a good bit.
les45
Images: 605
Re: Easy doorstop
Postby Oldragbaggers » Tue Apr 09, 2013 3:02 pm
Thanks Zach. I had no idea such a thing existed but I will have to get a couple of those.
Becky
Oldragbaggers
Images: 331
Re: Easy doorstop
Postby Alleged User » Wed Apr 10, 2013 6:48 am
We have the same issue. Our jalousie windows crank out at an angle, and that sharp corner can really mar the aluminum if we aren't careful when we open the doors while they're open.
Liking the tennis ball idea...perfect example of the K.I.S.S. principle. Don't really want to add any more hardware to the side, like Les mentioned. Will do something similar, though will paint our tennis ball silver so as to be all slick 'n stuff. :thumbsup:
Kelly & Duke
2011 ZZ Drop
Perhaps they are not stars, but rather openings in heaven where the love of our lost ones pours through and shines down upon us to let us know they are happy. - Eskimo proverb
Alleged User
Images: 81
Location: Northern Virginia...not to be confused with Virginia.
Re: Easy doorstop
Postby Kharn » Wed Apr 24, 2013 7:31 am
A small eye screw could also be used to hook the ball.
Kharn
Re: Easy doorstop
Postby Oldragbaggers » Wed Apr 24, 2013 9:08 pm
I got my baggage door clips and put them on last weekend. It was only $5 for a package of two. They look nice and work great.
Becky
Oldragbaggers
Images: 331
Re: Easy doorstop
Postby les45 » Thu Apr 25, 2013 6:39 am
Oldragbaggers wrote:I got my baggage door clips and put them on last weekend. It was only $5 for a package of two. They look nice and work great.
Becky,
Where did you install the clips? Do you have a pic?
Thanks,
Larry S.
les45
Images: 605
Re: Easy doorstop
Postby Oldragbaggers » Thu Apr 25, 2013 7:57 am
I do have a pic at home. Will post it this evening when I get home from work.
Becky
Oldragbaggers
Images: 331
Re: Easy doorstop
Postby Oldragbaggers » Thu Apr 25, 2013 4:54 pm
Pictures as promised.
They are very small and unobtrusive on the front of the teardrop.
But hold the door open and in place very nicely.
A very cheap and effective solution. I'm glad I got them.
Becky
Oldragbaggers
Images: 331
Re: Easy doorstop
Postby LDK » Thu Apr 25, 2013 6:04 pm
Since I made my own door I was able to use a door stop like this one.
I had to crank my window out all the way and bend the door stop to the right shape to keep the window from hitting the sidewall.
LDK
Re: Easy doorstop
Postby les45 » Thu Apr 25, 2013 7:33 pm
Oldragbaggers wrote:Pictures as promised.
Thanks, Becky
I ordered mine today.
Larry S.
les45
Images: 605
