You are absolutley correct Becky. I dont want to finish this one up and regret not doing something right. I did get about 5 hours this afternoon to start another phase of my build. I finished the subwall between the galley and the bunk area. I added a degree of dificulty by building an off-set wall to allow room for my 15 gallon water tank and pump. I also started the top cabinets in the galley. I'll work on the cabinet doors this week.... I also started pulling, soldering and shrink-wrapping the 12V DC power wires to all the lights, fantastic fan, and other 12V stuff. The 110V will be done tomorrow though. I need to do some research on a roof mounted vent fan to pull the hot air off my air conditioner... I may just mount another 14" roof vent up there with a manual opener. Any suggestions out there?
tomorrow will be a slow day... wiring, electrical hook-ups, wood puddy and interior sanding. I have about 8 hours of trim, sanding, painting, and detail oriented stuff to do this week before I attempt the base cabinets in the galley and install the water tank & pump. Otherwise, a hot, Sunny Carolina day of relaxation and a project!
