Making radiused corners.
Postby jeff0520 » Sun Apr 28, 2013 10:22 am
Does anyone have this set? http://www.rockler.com/product.cfm?page=5365&site=ROCKLER
If so, what do you think of it? $26.00 seems a little steep to me for plastic templates, but on the other hand, I need to make wooden clamp rings for my windows, and they need to be right. Comments would be appreciated :D
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Re: Making radiused corners.
Postby doug hodder » Sun Apr 28, 2013 11:01 am
The problem with this tool is: Are you sure that your radius for your specific window will be there? Can't you just trace the window inner rim to get the exact radius? I have several cheap compasses, the old type that held a pencil...also use any can in the garage for a radius. You're right...for as much as you'd use it...that's too much to draw a quarter circle. Doug
Postby halfdome, Danny » Sun Apr 28, 2013 12:06 pm
Rockler and Woodcraft are good at producing nonsense products that wouldn't be needed if one just used common sense like Doug mentioned.
I saw on the same page Cabinetmakers Pencils :? :? I've always used any ole' pencil laying around.
Save your money and use a compass, a can or a string with a nail on one end and a pencil on the other.
I have good laugh at all the silly products they offer when I receive one of their flyer's or catalogs.
They seem to have someone going through Cabinet shop jig piles re-inventing old jigs in plastic etc.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby les45 » Sun Apr 28, 2013 12:54 pm
I agree with the others, use an old can or a compass.
FWIW - I opened the link in Jeff's original post and now I get their advertising for those same templates popping up on all my web forums and Facebook. I guess big brother has taken over the internet.
les45
Images: 605
Postby Oldragbaggers » Sun Apr 28, 2013 4:42 pm
I've been known to use cans, plates, saucers, bottles, coins, jars....you get the idea. Just about anything round can be used as a radius. Just find something the size you're looking for that you already have and keep your hard earned cash in your pocket.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby GerryS » Sun Apr 28, 2013 5:28 pm
My saber saw has an arm that lines up with the cutting blade the other has a tack that holds it centered in place.. I can cut a circle with it accurately up to 23 or so inches in diameter. I've used this more than once....the last time to cut a hole in a patio table for my Kamodo grill. Worked like a champ!
GerryS
Postby Oldragbaggers » Sun Apr 28, 2013 6:11 pm
GerryS wrote:My saber saw has an arm that lines up with the cutting blade the other has a tack that holds it centered in place.. I can cut a circle with it accurately up to 23 or so inches in diameter. I've used this more than once....the last time to cut a hole in a patio table for my Kamodo grill. Worked like a champ!
I can't get it in my mind of what you're talking about, Gerry. Would love to see a picture!! :pictures:
Becky
Oldragbaggers
Images: 331
Postby GerryS » Sun Apr 28, 2013 6:29 pm
http://www.amazon.com/Festool-490118-Ci ... pd_cp_hi_2
You might be able to make a sled a standard saber saw would ride in. The Festool is an amazing tool if you have a budget for it. I can cut a inch and a half thick board keeping 90 degrees throughout the entire cut with a near finish ready edge. The down side is it isn't cheap...Like their entire lineup :(
GerryS
Postby bdosborn » Sun Apr 28, 2013 9:27 pm
A paint can was the perfect radius for my windows. YMMV...
Images: 806
Postby jeff0520 » Mon Apr 29, 2013 12:09 am
Ok, Makes good sense. Sometimes it's hard to tell at first glance when some nifty tool makes a real difference, and when it is just a waste. thanks for the input y'all :D
jeff0520
Images: 128
Postby Roly Nelson » Mon Apr 29, 2013 1:18 am
Keep your money, invest in a compass, the carpenter's best friend. I use them all of the time for many arcs, round corners, laying out equal spacing of screws and the sharp point is perfect for killing spiders...........no, not really.
Roly 8) :? Wood is good, just as me.
Roly Nelson
L'il Ol' Woody Builder
Postby GerryS » Mon Apr 29, 2013 5:21 am
Time is money...I've seen more and more "luxury" tools on job sites...the track saw can break sown sheet foods safer and faster than a panel saw, and you get zero tear out, or you can take 1/16 off the bottom of a door (again, no tear out) in just a few moments. All while collecting 90% of the dust....had Norm used that good of dust collection, maybe he's still be retired but he might not have COPD.
I've even seen tommy silva on "this old house" with a stack of systainers (festool transport boxes) in the background...not as a sponsored tool like porter cable or dewalt but what was being used
Ive got a couple tools from them. Yes, expensive. But when time is money while you are using a compass to set your layout lines, ill have finished the cut with a finish ready edge and have moved on to my next step before you for out your saw. Better...faster...smarter. A system that works together.
For the one project tool yeah, it's overkill. Bit if you plan on using them regularly, there isn't a comparison.
GerryS
