I spent some time cleaning up my garage yesterday, and we got some decent weather finally where I was able to spend an entire afternoon outside. I finished building my DIY Steambox for bending wood, and was able to bend a test piece successfully. I have updated my build blog at
http://www.diy-teardrop.com/2013/03/diy-steambox-for-bending-wood.html. I'm planning on posting many of the same pictures here as well. Lessons learned and things to try next time:
1. Soak the wood ahead of time. I wasn't expecting to finish the steam box today, so I forgot to start soaking my test piece. When I realized that I had plenty of time to try my first bend, I decided to put the test piece of dry red oak into the steamer for one hour. It was a thinner piece, so probably didn't need that much time, and don't expect to need that long in the future if I pre-soak. I plan on sending a few different woods through the steamer to see what bends the best, and I plan on trying White Oak, Ash, and Red Oak.
2. The test piece of red oak that I had was kiln dried. Green woods bend easier, and I have found a supplier that has some green oak. I'm not sure if soaking the wood will get some of it's elasticity back, but I have a feeling that Kiln dried wood loses some of that forever. I don't have too many extreme bends, but I'm sure that I'll discover what works best as I try different woods.
Success! A 90 degree bend using a 1/4" piece of red oak. This particular template is for the tongue box lid, if that makes any sense.
Next steps is to get a sheet of plywood that will serve as the backbone for my hatch template, and also front half template. The hatch template will have the next biggest curve, and uses the next smallest length of wood. Once I figure out what wood I'm going to use on the final skin, I should be able to have 3-4 templates at any one time. Looks like I'll need some more clamps.
