my240z wrote:Demo offically started. So I removed all the panels with a phillips bit but first had to figure out what the weird 8 sided bit was (crappy picture quality below). Thankfully I found a couple of blogs that talked about using a simple square drive would work and low and behold it did. I wish I would have payed more attention in math class. A square has four sides and a octogan has 8 side so a square bit if proper sized can be found will fit in an octogan...![]()
