Oreellyfool's Gnome Mobile build
Postby Oreellyfool » Sun Apr 21, 2013 9:20 pm
I think its time to kick off my build off.
My Northern tool 5x8 trailer got delivered yesterday.
105229
105230
I started putting it together today.
105231
105232
Now it's to a point, that I am going to take it to my dad's next weekend and weld up all the pieces so I'm not relying on the bolts 100%.
105233
Should be picking up wood tomorrow or Wednesday to start the floor and walls.
Until next time...
"There is nothing wrong with you that an expensive operation cannot prolong."
Oreellyfool
Images: 44
Re: Oreellyfool's Gnome Mobile build
Postby Woodbutcher » Sun Apr 21, 2013 9:24 pm
Good luck, and enjoy your build!
Woodbutcher
Postby Roo Dog » Sun Apr 21, 2013 9:29 pm
Oreellyfool,
Enjoy the project, it really is a good experience despite the occasional hiccup.
Git inta it !
RD
Lets do a three sixty and get out of here !
Roo Dog
Postby AlgoDan » Tue Apr 23, 2013 5:04 am
Good luck on the build, lot's of good info here. Keep us posted as you build.
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby Oreellyfool » Tue Apr 23, 2013 12:34 pm
Thanks everyone!!
I have definitely dove in. Last night I picked up a couple of cheap 1/8" 4x8 plywood sheets. Cut out two designs (as templates) and let the girl choose which one she wants. Hopefully by this weekend, I will have the actual walls cutout and will post some pictures then!
Oreellyfool
Images: 44
Postby Oreellyfool » Sun Apr 28, 2013 9:48 pm
I got some progress done this weekend. I took the frame down to my dad's house (he has a welder) and I welded up the top of the trailer so I did not have to have all the bolts.
I also taught the girl how to weld too. (This is her grinding off her first attempt)
105597
This is one of my welds (I won't quit my day job, but not too bad for only picking up a welder once a year)
105599
I ran out of time, so I did not get my compartments done, those will be done this week hopefully.
Oreellyfool
Images: 44
Postby Oreellyfool » Thu May 02, 2013 8:25 am
Go the bottom of the floor on. Also picked up all my wood for the sides and ribs.
105733
Oreellyfool
Images: 44
Postby Oreellyfool » Thu May 02, 2013 10:11 pm
I got the bottom all sealed up. Hopefully this weekend, I should have the insulation in and the bottom on and mounted.
105792
Oreellyfool
Images: 44
Postby Oreellyfool » Sun May 05, 2013 9:35 pm
Fairly productive weekend for how much other stuff I did beside working on the TD :thumbsup:
I got the floor insulated
105892
I got the top of the floor put on and bolted down to the trailer using carriage bolts and setting into the wood so they are below the surface. The dog was ready to test out the trailer.
105893
I got my sides cutout
105894
Also I was playing around with some door ideas and the girl liked this pattern so I went ahead and cut them out. I would say they are a little larger than what I was expecting, but I think they should work nicely (Plus with this size, I should be able to fit a larger window in there.
105895
Oreellyfool
Images: 44
Postby Oreellyfool » Tue May 07, 2013 9:50 pm
I call it abstract art......
The bottom of the walls are tarred and should be going on tomorrow.
106024
Oreellyfool
Images: 44
Postby Oreellyfool » Thu May 09, 2013 9:03 am
Got the main part of it put together. Moving right along. I was a little skeptical on how sturdy it would be by putting the ribs into the walls instead of just screwing through the side, but surprisingly, it is very sturdy and when i push on the wall the whole trailer moves and the walls do not flex.
106090
Oreellyfool
Images: 44
Postby Oreellyfool » Wed May 15, 2013 8:45 am
I have done quite a bit since my last post.
I got the interior panels on. I insulated the walls with window plastic (Between the outer plywood and the interior panels. I was reading about it and it has an R value of 1, so that is some insulation where I thought I would have none.
106436
The interior ceiling panels glued
106437
And the ceiling installed.
106540
Then after lots of filling and sanding of the staple holes, the staining began.
106596
This is the interior stained and the vent hole cut out.
106597
106600
Lastly, i also got 2 of the 4 jack stands installed, these sure are better than having to jack up the trailer and put car jack stands under it every time.
106603
Oreellyfool
Images: 44
Postby KCStudly » Wed May 15, 2013 7:45 pm
Looking good. :thumbsup: :applause:
Postby Oreellyfool » Tue Jun 25, 2013 9:13 am
I guess it has been a little over a month since my last update...... might be slacking here. Anyways, i have been busy....
Top is on
108662
Cabinets are built (less the doors)
108663
Rear hatch was made.... and then remade
108664
Fiberglassing has started. I used a polyester laminating marine resin with a 3/4 chop strand mat first then put a 6oz mat over the top... it should be waterproof....
108665
108666
I used a marine epoxy for my primer
108667
Now onto the paint scheme. getting close to being done.
108669
108670
108671
Oreellyfool
Images: 44
Postby kudzu » Tue Jun 25, 2013 12:58 pm
That's looking very good. Love the paint scheme!
kudzu
Images: 16
