I was responding to thread on iRV2 concerning the desirability/need of repacking wheel bearings on a trailer. Wheel bearing on an automobile will go years with out additional attention, so why can't a trailers. And the answer is probably that it can. if done well.
As with many things there are different grades of bearings, nine recognized. The bearings coming from where ever and not graded (all that I have seen) for trailers, lead me to think they probably tend to be at the lower end.
http://www.astbearings.com/bearing-tole ... evels.html
The other half of the equation is the grease used, synthetic preferred for high heat high speed applications
http://www.skf.com/group/products/beari ... index.html
When I do the inspection repacking of the bearings this spring I plan on, if possible replacing the Dexter bearings with, if possible, better quality bearings and seals and using Amsoil NLGI 2 grease.
One of the other purposes is inspection of brakes, and unless you have grease on them which speaks to the packing seals issue, all you should have to do is adjust as you used to do with pre disc brakes.
