by stanimal » Sun Jun 02, 2013 8:40 pm
After a few weeks of having to take care of other things, I got to work on the teardrop again this weekend. It got to be time to seal the wood. I had debated trying to skin it in sheet aluminum, but there are cost and skill considerations with that.
I had also thought of epoxy/fiberglass/paint, but again, some cost and skill considerations.
I had seen some folks talking about having Rhino lined their teardrops. When I took mine for a spin by the local Rhino place, they quoted me almost $900 to spray the whole thing.
I found a great product from Rustoleum canned Deck and Concrete Restore. I is an amazingly thick application. It will swell and contract with wood, and is totally and completely waterproof when it dries. It also apparently doesn't fade in sunlight. It doesn't dry smooth, and has a texture to it that is very similar to bed liner. The marketing says it is ten times thicker than paint, and I believe it. a 5 gallon bucket was a little over $70, and I applied two coats and have about a gallon or so to spare. It is about 1/8" thick after the two coats.
One of the nice things about it is that it will fill gaps and screw holes up to 1/4" without having to prep them. I chose the color "Linen." If I decide a couple of years down the road to go ahead with the aluminum, I can skin over this stuff and it'll all be good.
You can see the roll of living hinge in one of these pictures. Next weekend its attaching the hatch, the door, and installing windows. After that, it's just some detail work, and buying a deep cycle battery and installing that. I've tested the electric already by running jumper cables from my jeep to the fuse box onboard.
Can't wait to finish it up and take it out for a test run on a weekender.
- Attachments
- ImageUploadedByTapatalk HD1370222978.499171.jpg (17.03 KiB) Viewed 1608 times
- ImageUploadedByTapatalk HD1370222967.703269.jpg (21.38 KiB) Viewed 1608 times
- ImageUploadedByTapatalk HD1370222956.556112.jpg (19.44 KiB) Viewed 1608 times
