burlesot wrote:All,
Thanks in advance from a very newbee electrical system designer. Here is what I want to do:
I'm installing two 'porch lights' (red led's) over the doors on my teardrop. I'm thinking that it would be cool to tie into the marker lights (red and orange lights at front and back) so that when I turn on the porch lights, the marker lights come on too.
The marker lights will be on the wire harness from the car. Am I making something much more complicated than it need be? Should I just avoid trying to 'tie into' this?
Thank you,
Todd
burlesot wrote:SoCal,
I think I need a diagram for that.
However, thinking a bit on your idea. Are you basically saying that you could by-pass the marker lights (which are usually powered by the tow vehicle's battery) and instead power them from the teardrop's battery while towing? You would have to flip the switch on in/on the teardrop to have the marker and porch lights light up during towing?
burlesot wrote:I would, of course, have a line from the alternator/battery charging the teardrop's battery while driving, so I guess it's basically the same thing, right? Am I making this too simple?
Thank you,
Todd
burlesot wrote:Dale,
I'm not familiar at all with a blocking diode.
Can you put that in layman's terms?
I really appreciate all of the posts trying to help.
I especially appreciate your patience with my ignorance.
Someone quite wise reminded me that we all are learning.
T
