Cast Iron sleeping bag warmer
Postby Redgloves » Sat May 11, 2013 7:50 pm
A friend has talked about a sleeping bag warmer that was made of two cast iron pieces that contains charcoal, clamps together, and placed inside a cozy, then into sleeping bag.
I have never seen this device, but wonder if it really existed or a home crafted item?
Jean
Geocacher, healthcare provider, mom and women with not enough common sense regarding personal safety when it comes to adventure outings!
Owner:
Uff Da Inn, a 2015 Camp Inn 560
Redgloves
Images: 5
Re: Cast Iron sleeping bag warmer
Postby pmowers » Sat May 11, 2013 10:01 pm
I have never heard of one made of cast iron, but have seen plenty of bed or sheet warmers made from either copper or brass. Many were shaped somewhat like a skillet with a perforated cover and a long handle. You would fill it with coals then pass it back and forth between the sheets. Some would be filled with red-hot sand.
http://www.oldandinteresting.com/bed-warmers.aspx
pmowers
Images: 43
Postby aggie79 » Sun May 12, 2013 5:13 am
Sounds like a recipe for death by carbon monoxide poisoning.
Postby pmowers » Sun May 12, 2013 8:24 am
aggie79 wrote:Sounds like a recipe for death by carbon monoxide poisoning.
You have a point there. In fact, some of the early warnings said the healthy people do not need them, and the weak should use sand heated red-hot, to avoid the fumes. Normally, bed warmers were used like an iron, being passed back and forth between the sheets to take the chill off, not left in the bed.
When I was on winter operations, I would keep some of the instant hand warmers in my ruck. When we bivouacked, I would roll out my bag and throw 2 of them inside. After crawling in later, I would take them out and drop them in my boots. Warm sleeping bag at night, warm dry boots in the morning. 8)
pmowers
Images: 43
Postby Redgloves » Sun May 12, 2013 10:14 am
Should have added in first post that I knew could be death by CO2. Sand inside a container is a great idea!
Would have loved using something like this last weekend while shivering for 30 minutes to warm up teardrop bed.
Will have to experiment with old pie tins and sand. An old cake pan with a cover.
Owner:
Redgloves
Images: 5
Postby Woodbutcher » Sun May 12, 2013 11:51 am
That's what Bella is for!
Woodbutcher
Postby coop74 » Sun May 12, 2013 3:36 pm
believe it or not, just boil some water and put it in a nalgene bottle and put it in the sleeping bag with you. I will put a lot of heat into the bag and will actually stay warm for a long time.
Avoid direct skin contact however.
Big Coop
Robert "Coop" Cooper
coop74
Postby Dean in Ct. » Sun May 12, 2013 5:16 pm
I have 2 ceramic bed warmers, we always referred to them as "pigs". Just fill em with hot water and don't knock them over. They are actually heavy enough that when full it isn't likely. They will hold heat for a looooong time Also don't let them freeze! One of mine met that fate.
Dean in Ct.
Images: 32
Return to Cast Iron
