Simple On/Off Switch
Anything electric, AC or DC
Postby burlesot » Mon May 13, 2013 1:17 pm
All,
I realize my question is elementary, but I appreciate the advice I've gotten here and am sure that you all won't mind me asking this question. I would like to put in a simple, On/Off battery switch to my system. Can you help me decide what size/type to use?
Background: I have a 12 volt system; 6 circuit fuse/panel. Only four of the circuits are being used at this time.
Do I need an on/off switch for the battery?
If so, is there a 'standard' gauge/size? I took a venture to the Marine store and the only switches I saw there were super heavy duty.
Thanks in advance.
Todd
burlesot
Images: 62
Re: Simple On/Off Switch
Postby bdosborn » Mon May 13, 2013 1:22 pm
You don't necessarily need an on/off switch for the battery, these are more important for big RVs that have a lot of vampire loads that need to be disconnected during storage. The switch can be a handy way to make sure the battery is disconnected from any circuit you might forget and leave on. I put one in the teardrop and never used it so I left it out of the Boxcar.
You *do* need a fuse to protect the wiring to the battery, the closer to the battery terminals the better.
Images: 806
Postby bobhenry » Mon May 13, 2013 1:45 pm
I went looking for just such an animal and went into advance auto parts and found a 30 amp breaker with a manual disconnect. It's about as big as a pack of cigarettes and about 1 1/4 tall. I'll look for my fuzzy picture.
Here it is on the left. Image
The little red dot center left is a flip lever to disconnect the battery completely protecting it from accidental drain down.
Seem to remember it being in the 10 - 12 dollar range .
Postby burlesot » Mon May 13, 2013 1:58 pm
Got it.
Sounds like I don't NEED one, but do NEED a fuse inline. Will add an inline fuse and not a main on/off switch. I have a simple connect/disconnect that I use to connect/disconnect the teardrop to the battery.
Thank you,
Todd
burlesot
Images: 62
Postby halfdome, Danny » Mon May 13, 2013 2:47 pm
This is the simplest and cheapest way to go.
Goes on the negative battery post.
Available at Walmart in the $7 range.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby burlesot » Mon May 13, 2013 3:23 pm
I even understand how this one works! Simple and cheap!
Thanks,
Todd
burlesot
Images: 62
Postby GuitarPhotog » Mon May 13, 2013 5:30 pm
I use one of these battery disconnect switches from West Marine.
http://tinyurl.com/ctjg4tz
I like the idea of being able to disconnect the battery from everything with one switch, rather than with a wrench.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby H.A. » Mon May 13, 2013 6:43 pm
burlesot wrote:Got it.
The KISS method is to fit a fuse, Just remove the fuse instead of installing a switch also. Consider a switch would be another potential failure point.
Of course I am beyond following my own advice where everything is circuitbreaker protected along with other goofy stuff a series parallel switch set-up to provide higher voltage for charging the truck from my solar rack if needed...
H.A.
Postby alaska teardrop » Mon May 13, 2013 7:21 pm
    The black rectangle (above the positive battery post) with 8 ga. wire leading from the battery to the fuse box is a fuse holder from NAPA with a 30 amp fuse. As previously said, simply pull the fuse to disconnect.
    :peace: Fred
alaska teardrop
Postby GuitarPhotog » Mon May 13, 2013 11:41 pm
It's easier to turn off a switch then pull a fuse, and then keep track of it, and replace it when I need power.
Just turn the switch. On or Off. Like a beer tap, on or off ;-)
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Dale M. » Tue May 14, 2013 8:37 am
If you have to turn off beer tap..... Drink faster.....
A switch is more convenient.....
Dale
Dale M.
Images: 18
Postby burlesot » Thu May 16, 2013 1:15 pm
Danny,
Found one at my new favorite store: Harbor Freight. For $5
burlesot
Images: 62
Postby halfdome, Danny » Thu May 16, 2013 2:32 pm
burlesot wrote:Danny,
:thumbsup: Good deal.
I'll have to remember to get them there & save a couple bucks.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Return to Electrical Secrets
