Hi Shane,
What specifically do you mean by 'your deck is down with your flooring' ?
That the floor platform has been framed and covered with PT plywood ?
Or do you have a finished floor as well on top of that ? - just trying to get
the specifics...
In my opinion, PT is still to be avoided, but you could probably get by
with a continuous type of flooring glued over the PT plywood as floor deck
as that'd act like a vapor barrier [if continuous vinyl for example]. I'd then
be sure to caulk the seam/juncture of the flooring and walls to prevent any fumes
leaking in from there. And if you decide to keep it as is and continue with
the build, just be aware of the corrosion problem that Shadow Catcher
has informed us of. I had forgotten about that aspect, but since he has
pointed it out, I do now recall hearing/reading something about that in
the past, so that just reinforces my bias against PT for a build. Just make
provisions to be able to inspect the attachments of the floor/body through
the PT to the frame for corrosion in the future. Depending on what the
state of your progress is, maybe you could use some type of sleeve to
protect any fasteners used to go through the PT attaching the floor unit
to the frame ?
I can understand your concern for longevity, given the Maine environmental
effects, but the underside can also be protected with an undercoating of a
roofing tar-like coating or even the new elastomeric coatings. The most
intriguing approach to me is using some of the new Ice-shield/flashing type
membranes for that purpose. [
http://tnttt.com/viewtopic.php?f=21&t=45873 ]
Just something to consider...
Cheers,
Norm/mezmo
P.S. I just mentioned the above as a way to deal with the fact you already
have spent the $ and the time and effort to get the floor done. I still strongly
recommend not using any more PT elsewhere in the build.
