p.s. the converstion, was one of several we had in the couse of the weekend....
It consumes 38 amp hrs in 8 hours of operation.
Chris C wrote:Madjack, do you think a 175 watt inverter would run the charger you mentioned?
GeorgeTelford wrote:Hi Chris
I didnt want to rush it earlier, for that amount of charge 5-8 hours driving isnt going to cut it. A definate 8 hours would do it (we are talking invertor/charger here, with a smart reg 5 would fully charge no problem, but we are getting ahead here,lets spec this right.
To specify a system that will NEVER let you down I need some specific info from you.
How many consecutive days do you want to be out for? nights?
Will you be driving every day? without fail?
How many hours ( I Know you said 5 to 8 but will that be every day you are camping?)
What other equipment do you want to power and for hour many hours?
Have you got a maximum budget in mind for the electrical system?
I can show you how to make a manual regulator that will really boost charge the system for less than $5 and your time, but you have to be the brain that moniters the charge, would you consider timing it and altering a small potentiometer to mimic a staged charger? or would you rather spend $ 85 and have it fully automatic?
Steve read the links I added above a standard alternator is not a good charger in fact it is an extremely poor charger, its a power supply thats its Job. it just happens to replace the tiny amount of charge lost when starting a vehicle battery doesnt ever get above 65-70% charged.
