webbaldo wrote:Best TD ever!
down under tech wrote:Hello Dave: That is one "bee.u.tee.full" teardrop to see in person. Your fit and finish are to be commended! It turned out stupendously. The side trim really makes the statement that this is a one of a kind trailer. I had a great time talking to you at the Dam. Hope to see you guys and it in the wild again soon.![]()
Strop wrote:Hi Dave,
As a newcomer I must thank you for this detailed thread. It has me coming back all the time to check things out. I am still only in the dreaming phase while I learn how to use sketchup for some plans but I do have two questions for you please.
I intend to do you cardbord box trick when the time is right but I have to figure out what shape etc first and what size trailer to base it on. So - I am 6' 3" tall and 110 kg. I am thinking 5' wide but will I fit and be comfortable in 8' long or do I need a longer base. So how tall are you as from your comments you are obviously finding it comfortable. I will have to re-read the thread about your matress as well.
Second question - I could never find in your thread why you did not insulate the floor. You say there was some discussion and you wanted a strong floor but is there any other reason? Would you insulate if doing it again?
Thanks again for the thread.
Laurie
