This pic shows the ice chest on its shelf. My ice chest has a cooler cozy quilt to extend the ice life.
Oh and big doors! Big doors are very important.
.Strop wrote:Hi all,
I can see some of the limitations with a teardrop choice:
kitchen access in bad weather
Dressing / undressing room
Seating
Storage front cabinets
Limited space for tall people (I am 6' 2" +)
5x10 trailer with 8' from galley wall to front wall with 15" toe room under cabinets.
This sleeping configeration is a bit different but worked great with front cabinets.
Claustrophobic
see below
Toilets
Any assistance here much appreciated.
Laurie
Strop wrote:
Paul, I was thinking very seriously for a while about not insulating the walls after your earlier comment and then I read a thread on the Australian Yahoo Teardrop forum last night about a bloke camping in a tear and having to put his food into the esky to stop it from freezing. He also described sleeping in a sleeping bag within a sleeping bag. Tear was not insulated. What I found interesting was the location - just up the road from where I live. Found it quite funny as we have been to some family functions in the area and can always remember picking up the garden hose and having it snap in two due to the frozen water in it. Only 2 hours down the hill to the sunny north coast of NSW but two totally different environments weather wise. Decision made on insulation. I think I can get away without floor insulation with the foam mattress doing most of that work.
Laurie
I've built five in total now with another one on the go in the shed. The first one I built was done the American way with insulated walls, floor and roof. Since then I've realized that it doesn't snow much down this way and 15mm ply has an R factor of about seven. No need to insulate Mate. I only use 12mm for the floor.
alaska teardrop wrote:Since downunder wood has an extremely high R-value, you may not need insulation. American wood only has an R-value of one per inch (plus or minus a little depending on the type).
alaska teardrop wrote:Hi Laurie, Looking forward to your final design & construction ideas.
LauriePaul wrote:
I've built five in total now with another one on the go in the shed. The first one I built was done the American way with insulated walls, floor and roof. Since then I've realized that it doesn't snow much down this way and 15mm ply has an R factor of about seven. No need to insulate Mate. I only use 12mm for the floor.Since downunder wood has an extremely high R-value, you may not need insulation. American wood only has an R-value of one per inch (plus or minus a little depending on the type).
Fred
