qwerty11 wrote:My plans are to have the following:
~6,000 BTU AC, three inside outlets, & one outside outlet.
Interior outlets will have at times a space heater, blow dryer, and microwave plugged in.
Would it be best to have a 15A circuit breakers for the AC and two 30A circuit breakers a pair of outlets each?
Also in regards to GFCI: What is the general consensus of circuit breakers with integrated GFCI vs outlets?
Thx!
George Taylor wrote:Not sure what you mean by a gfi can only protect down steam? A GFI will protect only things wired after it (downstream) not things wired before it. A gfi outlet will protect itself protect itself from what? and if wired for it as many outlets as you want yes you can multiple several outlets off of one GFI. You can use a gfi breaker, but they are more expensive and may not fit in some of the smaller breaker smaller or in my case the ac/dc converter. Outlets even the ones that say 15 amp rated still have a 20 amp feed throu, why...who knows. Even though the current drawn from one outlet should not exceed 15 amps the total amperage of all the outlets on the circuit may be equal to the 20 amp rating of the circuit breaker and the 12 gauge wire used to wire the entire branch circuit. You should be able to run 2 small heaters as long as they do not use more amps than they are rated for and the total, as you mentioned, do not exceed 30amps. I doubt that you can run two small heaters (or similar devices) off of one 20 amp circuit w/o tripping a twenty amp circuit breaker. That's why two two separate circuits were suggested.
George Taylor wrote:DC current is more susceptible to voltage drop than AC. If I can find it I will post the formula to calculate what the voltage drop is on a specific wire/legnth. I know either someone on here has it or you can find it online. However the lengths of wire we are running, unless you decide to wrap the entire trailer with it, are so short the drop is so minute it won't affect anything. 110v is nominal. I have seen it vary from about 104 to 126v.
