Shadow Catcher wrote:What you are thinking of is a clevis or bow shackle![]()
I have a tow strap that I use them on but finding ones of the same strength and diameter as the chain was difficult.
Shadow Catcher wrote:I used a quick link that had to be "persuaded" to go through the link and is the same diameter as the chain.
Rolly wrote:Possible solution for hooks.http://www.tulsachain.com/asccustompages/products.asp?AffID=&categoryid=438&navParent=437
Rolly
les45 wrote:I decided to replace the hooks on the safety chains on my NT trailer with Reese quick connectors for a more positive hookup. When I went to spread the hooks to get the chain off, they both shattered in exactly the same place and with the same type of failure. I was wedging them apart with just a couple of light blows on a chisel when they broke like this. I'm figuring that is not a good thing. I looked this up online and found other similar hook failures that occurred on the road with Chinese made parts. Unfortunately, when I looked at the Reese packaging, the quick connectors were made in China too. Now I'm going to replace the chains and connectors with something American made (if there is such a thing nowadays).
