Whatcha do on your build today?
Re: Whatcha do on your build today?
Postby Roly Nelson » Tue May 14, 2013 1:07 am
I parked the Shrunk-bunk in the shop. Still trying to figure out how to keep the plywood sides from rubbing against the inside of the tires. Not a big deal, but I think it rubs when I hit a bump. Next step, find out where it binds when I try to lower it for haulng down the interstate. Oh well, still some kinks to iron out, but all in all, since I made the fold-down cabinets shallower, I now have breathing room above my face, when I am in bed. At the Dam, I had 4 inches, and that is too close to try to read anything prior to sleeping.
:) 8) :thumbsup: Roly, with other designs bouncing through my head like sugar plums, Oh the plague I have created.
Roly Nelson
L'il Ol' Woody Builder
Postby len19070 » Tue May 14, 2013 5:48 pm
WOW!
After a Looong delay ( I do have to go out and make a living at some Point) I'm finally back at it!
Finished all the rear trim, most of the Vinyl inside the galley and started on the galley its self.
the galley will be done in Vinyl and Formica.
and the inside in Rug.
More to come.
Happy Trails
Len
len19070
Images: 24
Postby len19070 » Wed May 15, 2013 6:27 am
Oldragbaggers wrote: I am all finished varnishing, thank you very much!!
:applause: :applause: :applause: :applause:
Happy Trails
Len
len19070
Images: 24
Postby Desert-rat » Wed May 15, 2013 6:13 pm
I finished cleaning my garage so I have space to put the trailer in.
took some measurements and created more designs in sketchup 8)
Desert-rat
Images: 11
Postby working on it » Sun May 19, 2013 9:17 pm
2 steps forward ... 1.5 steps back....Gaining a little, but major set-backs at every turn. Cut spaces for windows...a gain...added toolbox and bracing to tongue...a gain...learned that my A/C ducting is insufficient (have to add an in-line duct fan)...a loss...while putting on the bracing to the tongue, I had my tape measure under with me so I measured the axle size (I thought I had already done this 20 months ago), it's only 1.25" cambered square tube not 1.5" as I thought...a loss. I can fix the A/C problem, but with the estimated running weight of the loaded trailer approaching 1400 lbs, even with the upsized spring hangers, axle stubs, bearings, wheels and tires already done...I fear that I'll have to go bigger. Or reinforce. More weight.
173193172890148599
working on it
Images: 457
Postby Fyddler » Sun May 19, 2013 10:29 pm
Built a fender! I wasn't sure how it was going to turn out but I think it looks good! I had to mount with a couple screws temporarily so I could see em what it looked like. Still need no trim It and route the edges.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Postby Roo Dog » Mon May 20, 2013 2:49 am
Fyddler,
Nice job.
Really looks the part.
RD
Lets do a three sixty and get out of here !
Roo Dog
Postby Desert-rat » Sat May 25, 2013 8:00 pm
the bargain trailer went on a diet today
Image Everything that got cut off
<sorry for large pic> :pictures:
100ish pounds of unnecessary weight
Killed a brand new Harbor Freight grinder too
Desert-rat
Images: 11
Postby Shadow Catcher » Sat May 25, 2013 8:46 pm
What is green and fuzzy, Mold! Had a water leak that I did not catch and it got some of the wood in the galley wet and :?
This was a couple of weeks ago, I cleaned it and used CPES. The wood work had a minimal finish, certainly not water resistant.
Also finished the new cord/seven blade which I was working on when I had the heart attack six weeks ago, (I am doing very well).
Finished the install of the Progressive Industries EMS.
New SKF wheel bearings and Amsoil synthetic grease for the Dexter axle.
Postby Oldragbaggers » Sun May 26, 2013 8:46 am
Sorry about your mold, Shadowcatcher, but it sounds like you caught it and got it handled before it did any real damage. So glad you are feeling better and back to doing the things you enjoy.
Today, come hell or high water, by the end of this day my hatch will be hanging. Hope to also get the rail and leg on my extension table and get the prop poles put together and in place. Beyond that, we'll see.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby nevadatear » Sun May 26, 2013 3:33 pm
So last fall we were out at a friends farm and i noticed some old commercial awnings, and they were the same fabric as my awning! Seems he only wanted the framework, and was happy to get rid of the fabric. It was torn and worn in a few places, but not faded at all. Sumbrella wears like iron. So i cut it off, patched it ,and turned part of it into a tablecloth yesterday and today i made one wall for the easy up. There isn't enough for another full wall, enough for a half a front wall, and we will make do with a tarp for the other wall when needed. So now, after @8 hours work and @20buck for the vinyl window and re-waterrepealant spray, we are set for wet or windy teardrop weather in style!
Outside
Inside
nevadatear
Images: 171
Postby nevadatear » Sun May 26, 2013 6:56 pm
Thanks, Mike. Recycling, repurposing and reusing at it finest!
nevadatear
Images: 171
Postby working on it » Sun May 26, 2013 10:26 pm
Got one window in yesterday...had trouble with the OSI Quad squeezing out onto the interior window metal (not easy to remove, unless you have paint thinner ready). Installing the wood trim (to cover the oversized hole and inletting I boogered) around the inside window frame was a bear, cut once twice thrice.... Oh well, the black trim matches other black trim, and my errors become lost in their midst, I hope. Only did one side, since I hope that I can do the second faster and better. ? about the screw covers...is there a trick to get them to stay in the channel? Or since I am going to cover the screw heads with sealant, I may just fill in and smooth and paint the channel anyway. No pictures, my digital camera needs a battery, and my wife has hidden her really expensive cameras from me. Maybe tomorrow.update Finished the other side today...went much smoother, used adhesive in better placement (less cleanup). Digital camera still out, cellphone photos: 107292107294
173193172890148599
working on it
Images: 457
Postby Oldragbaggers » Sun May 26, 2013 11:03 pm
Nice score with the fabric Debbie and beautiful job on the wall.
Becky
Oldragbaggers
Images: 331
Postby Vedette » Sun May 26, 2013 11:12 pm
Sandi just cleaned out Miss Piggy from our last camping outing last weekend, where we experienced "record rainfall" on the first night there. We learned how to put up the new ezee-up in the dark and in a down pour! :cry:
Found the areas that leaked and have plans to seal them.
Still no headliner. :(
Busy on customers cars! Don't know how I thought I was retired?????
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Users browsing this forum: Google [Bot] and 1 guest
