rollintent wrote:I read somewhere that if even a small shadow hits a panel that is otherwise exposed to direct sun maybe even 5% of the panel shaded it will be totally unproductive or shut down as it was put in the article. Wouldn't this be the case in the full shade situation? Or, Would it be that the whole panel recieves a reduced but even amount of light across all of it's cells would it just have much reduced output.
rollintent wrote:Is anyone running their solar panel not attached to the roof of the trailer, parking the trailer in the shade and running a short cord out into the sun and placing the panel on a stand some relatively small distance from the trailer where it would get direct sun exposure.
eamarquardt wrote:I think this statement precludes one from fully charging a discharged battery in a mere twenty minutes:
"9.1.1. The BULK stage is where the charger current is constant and the battery voltage increases, which is normally during the first 80% of the recharge. Give the battery whatever current it will accept as long as it does not exceed 25% of the 20 hour (expressed "C/20") ampere hour (AH) capacity rating so, if you can only put back in only 25% per hour it's gonna take 4 hours to get back to full charge, 10% of the Reserve Capacity (RC) rating, I'm not sure if they mean you can't put in, in amps, more than 10% of the RC time, in minutes, or not but they seem to be clear that there is a definite limit to the current one can safely use of the wet batteries do not exceed 125° F (51.5° C), and VRLA batteries do not exceed 100° F (37.8° C).
If you discharge a 100amp/hour battery you can get about 50 amp hours from it. If you want to put that back much power back into it in twenty minutes yer talking 150 amps which far exceeds any interpretation of the guidelines above. It just ain't a viable plan.
Cheers,
Gus
If you decide to go the generator route. The last 10% to 20% of the charge takes a long time. Why not just skip it. Use a deep cycle battery down to 60% charge, and then recharge it back up to 80% to 90%. You don't need to recharge a lead-acid battery to full charge each time. In fact during recharge when nearing full charge is one of the periods when the battery takes the most damage. Figure out how much fuel the generator uses per hour when charging, and only give it enough fuel for the time you wish to charge. When it runs out, charging stops. A full recharge and equalize only needs to be done every couple weeks, and that is something that is maybe better done when hooked up to the power line, or using a solar system.rollintent wrote:How long will it take to charge a 100-130 amp hour 12 battery back to 100% from an 80% full state with a small generator and a good automatic charger? If I can charge the battery once or twice a day with the generator running for one to maybe three hours I would be happy with that. I am also needing advice on brands, sizes, and types of chargers that have proven themselves through use with people that really rely on them.
