The latest scoop of poop here in Finland is this.
As of 2010 January. In order to get the teardrop or mini caravan fully inspected there is an additional lighting & electrical inspection and certification.
This must be done by a trained & appointed EU lighting inspector..cost of 60 Euro.
(One Time Requirement). They check and measure the location of the lighting, circuitry, and that its all Eu Approved and Marked lighting.
Also for 220 - 230 volt elctrical must be done by a certified electrician. As well as any gas lines, must be done again by a licensed or certified tech.
All lighting must be seperately inspected in addition to the normal Model Type Inspection which now costs a luscious 300 Euro. If any accessories are to be sold or used it must be mentioned at the same time. Such as possible different style, size of tires, wheels, air condtioning, stoves and the poop goes on. If its not mentioned then these accessories cannot be used or sold with this unit afterwards. So have to get all possibly to be used goodies and extras mentioned upon inspection.
This now is on the 1st tear Model or Unit. After this if you build the same style or model after this inspected one then the normal fee of 60 Euro + Electrical Inspection.
Now as far as the chassis goes. Since I dont weld much. My colleague who has been making utility trailers of all kinds as a business for over 30 years is really up to date with this crapola here.
He is welding all of our frames, installing the approved axles, towbar and whatever else I want on it. Inspects it and Registers it. Comes to us as a pre inspected and licensed.
We build the so called body or box.. take it back to my colleague and he runs it over to the beauracrats once more. Its final inspection is done and On the Road Ya Go. Less BS and Beauracratic headache.
Also since my colleague is licensed to do all of this its a whole lot easier.
The 1st Type or Model that you build is the most costly. And if no changes are made on the 2nd or 3rd up to the 100th unit the fees arent as bad.
So here you have to try to keep the lighting the same, and as well as the positions of to keep the inspectors happy.
The towbar cannot be bent or welded anywhere. If you have a special towbar that you want to have tested & approved. And certified. The cost is at 6000 Euro. Plus different fees.
The towbar thing is a Monopoly here. And a money making loop only.
The fully welded ones such as I had before it was cut of and a Brussels Towbar fitted was in my opinion better made, higher quality and safer versus 4 bolts that holds it in place.
Do I agree with this crapola
Its the Officials here that run these laws thru Parliament that dont know poop about trailers, caravans or teardrops. Bunch of airheads in a huge class room trying to act smart.
