GarArnett 6x10 Conversion in eastern KY
Re: GarArnett 6x10 Conversion in eastern KY
Postby GarArnett » Mon May 27, 2013 8:35 pm
Framed the ceiling vent. Just a normal vent, not a fantastic fan.
GarArnett
Postby GarArnett » Mon May 27, 2013 8:37 pm
Wall insulation is in.
GarArnett
Postby GarArnett » Mon May 27, 2013 8:38 pm
Vent is in.
GarArnett
Postby GarArnett » Mon May 27, 2013 8:39 pm
Better picture of outside with vent installed.
GarArnett
Postby GarArnett » Mon May 27, 2013 8:44 pm
I also sealed the gaps up front in the floor with "great stuff". Bought the panels I'll be using for the interior. I've got a few decisions to make before moving on, specifically about how I'm doing the front cabinet area and how much wiring will be done. Then the sides will go on. Hope to go ahead and paint or stain the sides next weekend in prep for install.
GarArnett
Postby roadinspector » Mon May 27, 2013 8:56 pm
LOOKING GOOD!! :thumbsup:
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby Rainier70 » Wed May 29, 2013 8:44 am
Moving along nicely. :applause:
Rainier70
Images: 244
Postby rebapuck » Wed May 29, 2013 9:09 pm
You've gotten the ball rolling. Stay with it.
Amazing how much light a little hole in the roof can supply.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby GarArnett » Mon Jun 03, 2013 1:58 pm
No progress this weekend. Actually, have to back up. I used the trailer on Sunday to move some furniture and it was raining. No, my roof vent didn't leak, but the front was soaking wet inside. Now, I'm going to remove the insulation and see what I can do to waterproof the front of the trailer. Thinking about roll-on (or spray can) truck bed liner. We'll see what happens. Was hoping to have the interior sheeting up by this weekend, but looking doubtful now.
GarArnett
Postby rebapuck » Mon Jun 03, 2013 4:48 pm
There are alot of seams on the front. Can you just caulk them?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby roadinspector » Mon Jun 03, 2013 11:16 pm
GarArnett,
Now you know why the floor was in bad condition in the front. You could go out when it is real dark one night with a helper. Have the helper shine a light all over outside the CT and look for the light shining thru. If the skin is good and it is just the seams you could just seal them.
Earnest
roadinspector
Images: 127
Postby racerrandy » Sun Jun 30, 2013 10:44 pm
I have done auto glass for many years and would like to give you a little advice on finding and fixing leaks.
First, use a hose to check for leaks and when you find it, fix it from the outside. When you try to fix from the inside the water will just migrate somewhere else and still come in.
Start low on the trailer with the hose and gradually move your way up. If you just start running water all over the top, its very hard to discover the source. When you get to the top, hold the hose to one side and then the other. You are going to need someone inside helping with a flashlight or they can run the hose with you inside.
I honestly don't know the best product for a trailer, because its different materials than a car. I would ask here or a local trailer/camper sales place. When you find out what kind of sealant to use and get your leak fixed, share it here so we will have that info.
Hope this can help in some way. :beer:
Randy
racerrandy
Postby GarArnett » Sun Aug 04, 2013 11:10 am
I sealed every seam from the outside with silicone caulk like I used on the roof vent. Seems to have worked. Got 1 coat of paint on the floor and stalled for a bit. I did get new led tail lights in though. Hoping things will calm down so I can get back to work on it.
GarArnett
Postby GarArnett » Sat Nov 16, 2013 7:43 pm
Finally got back to work last weekend and this weekend. Hope to get a little more done Sunday. Got some nice LED wireless lights to use around the inside - hope to install 2 tomorrow also.
GarArnett
Users browsing this forum: Google [Bot] and 4 guests
