Screws or Nails
Screws or Nails
Postby qwerty11 » Thu May 30, 2013 1:21 pm
Which one did you guys use for your frame?
qwerty11
Re: Screws or Nails
Postby TPMcGinty » Thu May 30, 2013 1:27 pm
qwerty11 wrote:Which one did you guys use for your frame?
The frame was welded. I used screws to attach the floor to the frame.
Tim
TPMcGinty
Images: 146
Re: Screws or Nails
Postby les45 » Thu May 30, 2013 1:40 pm
I used carriage bolts to bolt the 5/8" plywood deck directly to the trailer frame using the existing holes in the frame. I then used longer carriage bolts and fender washers to bolt the perimeter nailers (2X4 on the sides and 2X6 on each end) to the plywood deck. Then used 3" deck screws to fasten my 3/4" side walls to the nailers. (some folks might say that I tend to overbuild but I sleep well at night)
les45
Images: 605
Re: Screws or Nails
Postby qwerty11 » Thu May 30, 2013 2:04 pm
Guess I should have clarified. Your wood frame of the camper not the trailer.
qwerty11
Re: Screws or Nails
Postby Forrest747 » Thu May 30, 2013 5:40 pm
i used drywalll screws, to some is heresy, there are plenty of good wood screws and if you do pocket jig plenty of screws for that. Mc Feelys comes to mind. http://www.mcfeelys.com/
i am told and believe taht the screws hold the pieces together until the glue sets up. I used Gorilla wood glue but hear titebond 3 is better.
Other than brads to hold the interior paneling up till the glue set, i didnt use any nails.
Forrest747
Cowbell Donating Member
Images: 447
Re: Screws or Nails
Postby Roo Dog » Thu May 30, 2013 6:10 pm
Screws and construction adhesive.
Staples and construction adhesive when laminating the two sheets of 3mm of ply for the roof.
All covered with glued steel sheet.
Appears to have worked.
Take it easy
RD
Lets do a three sixty and get out of here !
Roo Dog
Re: Screws or Nails
Postby 48Rob » Thu May 30, 2013 6:21 pm
Screws and nails, better to have a backup plan.
Rob
48Rob
Re: Screws or Nails
Postby markhusbands » Fri May 31, 2013 2:30 pm
So far, Titebond III and wood screws, many of which are Kreg pocket screws.
Also used some pneumatic brads and staples for 1/8 ply attachment (with Titebond III). But no conventional nails at all.
133923
markhusbands
Images: 58
