A drawing of the design & an estimated weight of the trailer that you have in mind would be helpful in answering your questions. If the #1 frame rails are 3/16"x2"x2" square tubing, the capacity would be 2240# for a trailer with a 3' tongue.
Fred
[/quote]
Hi Fred,
I was just up in Alaska a couple weeks ago, and enjoyed the trip- mostly around Anchorage.
Here is an image of my version of your frame.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3037&image_id=107587)
I hope that the teardrop/trailer combo would be 7-800 lbs. I would construct the tear with a torsion box floor, with foam walls and roof covered in Canvas in the Foamie tradition, and from what I've read, this would be a torsionally strong tear. I would like to be able to take off the tear, and put on a utility frame, likely made out of angle ironor square tube, and have a gross capacity of 2400lbs (Subaru Forester TV.) I don't have a truck, or easy access to one, so having a utility trailer would be nice to pick up sheet goods from the lumber yard or doing landscaping stuff, and if I can make one trailer do the job of two, that would be great in my books. I would be sure to use lockwashers or nylock nuts on the attachment bolts, and use grade 5 or higher.
A couple notes on my drawing:
I put 2x3x1/8 for the main members- According to angib's link here (
http://www.angib.pwp.blueyonder.co.uk/t ... tear84.htm) it is stronger, but lighter. I am not sure if I should use it for the axle attachment points as well or if 2x2x1/8 would be sufficient. Also, I initially put 2x3x1/8 for the rear member, but I wonder if I could go with 1.5x2.5x1/8 instead.
The axle attachment points would have holes drilled every 2 inches to allow for some adjustment of the axle position for balancing.
I would use a Flexiride or Dexter axle
Attachment points are marked with an x
Thanks for your feedback,
Brendon
