The wiring is DONE! I had a lot of fun working on the trailer this weekend. I made a ton of progress and it looks like I will make my goal of finishing before the our first trip on the 19th!
The wiring compartment.
The Turnigy Watt meter is a great addition. It shows the instantaneous watt/amp usage, total amp hour usage, peak watt/amp, voltage, basically everything! It was less than $30 bucks and should be an amazing tool.
Tested all the lights to make sure they are working.
I installed the hatch latch and cut the bars just enough so it will close. Once completed I will need to go back and trim the bars to the exact length to fit into the walls when in the locked position.
Here's an interesting picture but it requires a bit of an explanation. I used Google hangouts to setup a video chat between my phone and tablet. Why do this you ask? It allowed me to place the phone in the hatch and close the door in order to view the clearance of the lights and counter. The video was transferred outside to my tablet from which I took this picture. I say I have about 1/4" clearance.
I installed a new trailer hitch and wiring kit on the Ford Escape. The trailer fits PERFECTLY behind the Escape and will tow just about parallel to the ground. This is the first time I tested the new wiring harness on the the trailer, and the first time the trailer light circuits were truly tested as well. Fortunately everything worked great and I breathed a sigh of relief!
Installed the switch panels and plate which control the outside porch light.
Installed the stabilizer jacks. I need to do this before the outside skins can be installed as I need to take off the wheels.
Finally the finished wiring pics!
Here is the soon to be enclosed compartment above the wiring/fuse compartment which will be covered by the outside skin. This location contains the splices for all the wire runs which then continue to the the fuse box below. I have designed it so if I ever need to get access to the splices, I can pull them out from enlarged holes in the top of the wiring compartment.
Here is the location of my wiring exit in the front to the tongue box. I have conduit cover which will screw into these backing blocks once the outside skin is on!
Next up the outside skin!
