Crazy idea?
Anything electric, AC or DC
Crazy idea?
Postby Jeffsst2 » Tue Jun 11, 2013 10:02 pm
Hello everyone, I have learned a lot from this site! Now for my first question. I have a flat 4 trailer connector, I believe that the 2 brown wires are the power wires. Could I tap into both on the trailer side and create 1 larger wire to then charge my house battery while driving? I will fuse with a 30 amp inline fuse before the house battery and disconnect while camped.
Thanks, Jeff
Jeffsst2
Re: Crazy idea?
Postby coop74 » Tue Jun 11, 2013 10:04 pm
use a volt meter to determine which is power. On some wiring harnesses brown is ground (german ones for sure).
You really dont need a huge wire to slow feed your battery juice to keep it topped off by the way.
my two cents.
Robert "Coop" Cooper
coop74
Re: Crazy idea?
Postby Jeffsst2 » Tue Jun 11, 2013 10:47 pm
Would it be better tap both power lines?
Jeffsst2
Re: Crazy idea?
Postby alaska teardrop » Wed Jun 12, 2013 6:05 am
    The brown wire is intended for the tail lights. Connecting a battery to it would light up the trailer & car lights full time and may cause damage.
    :peace: Fred
alaska teardrop
Re: Crazy idea?
Postby Dale M. » Wed Jun 12, 2013 8:02 am
Generally if you want to charge while towing, you ruin a separate wire from source on tow vehicle (fused power from battery) to the battery in TC through its own separate pin on connector... Usually this requires changing out a flat 4 connector to a 5 or 6 or 7 pin connector...
The e-trailer link about wiring posted by someone else is pretty good... Also see "sticky" about "Charging While Towing"...
viewtopic.php?f=30&t=28620
Dale
Dale M.
Images: 18
Return to Electrical Secrets
