FoamStream...
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 6:20 am
Dodge', after considering many possibilities , the CNC was the easiest for me to do, and luckily I have a good friend with a machine ... Had we chosen to buy the pre-bent “wagon ribs” , it would probably have been more expensive than renting the CNC :o ...and still not what we wanted ... :roll: The router and template method would work ... All what’s easiest for you to do ... ;)
A Bowlus would be Nice !!! Not that difficult to do for someone with some fuselage experience ... ;)
Norm, the nose will have an integral “shelf” built in to add some strength and “utility” to the nose ... :thumbsup:
We’ll have to think some more about adding the extra ribs...the quarter sphere is still the only part that we’re still thinking about ... I could easily see a center rib , running from the roof peak to the nose center, establishing that shape .. and tying in the skeleton to the nose cage ... That sounds reasonable ... :thinking:
Depending what kind and size of foam I can get , the nose (sphere) could be as much as 10” thick ... :o More likely half that ... :NC
The nose floor support is working out just fine , everything fitting in place , and should be plenty strong enough with several attachment points along the front and inside too ...
OSB, that will be liberally treated with "the mix” (then painted ) on the inside and exposed edges , and of course all the bottom will get an application or two of the black nasty stuff... That should work OK.. The Foamie #1 after all this time is still in great shape ... no problems to report ...so I’m confident of this method ...
Having owned a commercial RV trailer , with an obviously untreated OSB floor on either top or bottom , we know for sure that won’t work ... :frightened:
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 7:44 am
Here’s the floor piece fitted up and marked for cutting to shape ... supported by a block of black Limba , all attached to the HF clip and tongue .. with a secondary support (the 2X4) which will also be trimmed to size and treated ... again ...
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 8:24 am
Floor cut in the nose .... the 2X4 that sticks out on the side will be “blended" with the belt sander as to be less obtrusive ... now to glue , screw and bolt it all up ... :D
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 8:36 am
A little pre-trim with the handsaw helps with bulk wood removal ... the belt sander will smooth everything up ... :D
Getting HOT now ... Have to move inside ... :fan:
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 8:50 am
Not to be too OT , we’re working (still crude at this point ) on a PVC bending to heat bend PVC plumbing pipe to a specific shape (Hint: Archery) ... And it wouldn’t be unreasonable to be able to bend “Ribs” out of this stuff ... It’s pretty TOUGH , and really INEXPENSIVE ... a 10’ length of 3/4” PVC pipe is around 2 bucks ... certainly worth investigating as a rib material ... :thinking: Many possibilities ... and with common fittings available , even more possibilities ... :o
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 9:40 am
Floor front screwed and glued ... Cage attached to that ...
And it’s now off to the store for more T2 ...
Re: FoamStream...
Postby kudzu » Wed Jun 12, 2013 9:41 am
It's all taking shape now. Great progress, GPW. And thanks for feeding the needs of the masses by supplying pics & explanations.
kudzu
Images: 16
Re: FoamStream...
Postby GPW » Wed Jun 12, 2013 9:57 am
Not meaning to bore everyone with all this little detail stuff... just trying to show how easy it is ... using simple tools ... :D ( and a CNC machine :roll: )
Apologies for not going out and buying Another sheet of OSB , just so I could have a one piece front floor ... I’m just too Thrifty for that (read: cheap bas***d ) :lol:
Re: FoamStream...
Postby Wobbly Wheels » Wed Jun 12, 2013 11:13 am
You'd better apologize for that, mister. It's not like you can build it the way you want to !!
:lol: :lol: :lol:
In lieu of being able to make any real progress of my own at the moment, I'm enjoying watching your progress.
Wobbly Wheels
Re: FoamStream...
Postby wagondude » Wed Jun 12, 2013 8:06 pm
GPW wrote: Apologies for not going out and buying Another sheet of OSB , just so I could have a one piece front floor ... I’m just too Thrifty for that (read: cheap bas***d ) :lol:
As one cheap bas***d to another, you better use all that wood. It aint like that stuff grows on trees. Oh, wait..... :shock: :lol:
Bill
101137
wagondude
Images: 35
Re: FoamStream...
Postby GPW » Thu Jun 13, 2013 5:21 am
Can’t burn the scraps anymore , that releases carbon ... Global Schwarming ‘ :roll: Have to bury the scraps ... or just use them eh ... ;) Maybe make a nice OSB spice rack for the FS ... ? :NC
Re: FoamStream...
Postby GPW » Thu Jun 13, 2013 5:03 pm
Nothing going on today ... had to bring the wife to the airport for 08:00 , she flew into Philly (PHL) in the middle of all those Storms ... :frightened: What an Idiot!!! All those many extra years of College did naught for common sense... :roll:
Then had to run (drive) from there to get the wife’s truck oil changed ... Now what normally takes 15 minutes at a “normal’ oil change place took 3 (THREE) hours at my friends place , sitting around listening him babble on about various subjects , swilling spring water , and listening to every Led Zeppelin song ever made ... in the HEAT ... :o :shock: :?
Then had to rush home to make sure I was here for the wife’s “cosmetic” deliveries (which have yet to come ... still waiting ) , meanwhile , I spotted a big black snake in the yard right next to my Studio door .. :frightened: Checked it out ... round eyes , so not poisonous... but it’s still pretty BIG ... :shocked: There go the toads ... :cry:
Went in for a little afternoon siesta ...get comfortable on the sofa with a cooking show on ... the phone rings ... it’s the wife telling me she made it .. :applause:
But nothings going on .... :roll:
Ps. Looking forward to getting back to trailer building .... just for the rest ... :beer:
Re: FoamStream...
Postby kudzu » Thu Jun 13, 2013 5:25 pm
Sounds like you managed to keep yourself occupied while there was, "Nothing going on today ..." BF has a degree in physics yet he'll get on a plane anytime they'll let them take off. I'm the one who worries about it but I remind myself that statistically I'm in more danger driving him back & forth to the airport than he is on a plane in stormy weather. So we'll get more pictures tomorrow? ...asks the girl who hasn't even purchased foam yet... :lol:
kudzu
Images: 16
Re: FoamStream...
Postby GPW » Thu Jun 13, 2013 5:29 pm
Lets just say you’re still “shopping" for the foam ... and that can take "some time" .... ;)
Re: FoamStream...
Postby GPW » Fri Jun 14, 2013 6:58 am
Today , the plan is More kerfing ... :o :frightened: Those front panels ... The last of kerfing for a while ... we hope .. :NC That’s after we run to the HD for more glue (T2) and Great Stuff... I managed to use up the 1/2 gallon of T2 left over from the first Foamie build ... Thrifty!!! ;)
If my Math is correct (seldom is ) the 10’ panels will just fit the curve of the nose cage ... ( If? ) :R
Discussing the “door" with the wife , I told her of my mistrust of anything labelled “RV” , as being made as cheap as they can (therefore , unreliable ), so It’s been decided (by you know who) that I will now make my own door and frame .... Screen door is out , a screened window on the door is acceptable ... for now ... :roll:
Bottom line , with a bit of Salvage , we’ve only spent around 400USD so far ... There’s still the skin , paint, tires , and some hardware to buy as yet .... but it looks like well be spending ~ $1K .. works out roughly to about a dollar a pound (can’t even buy Frozen Turkey for that anymore) or $13.80 per sq. ft. (very Thrifty) ... :thinking:
