Well I have asked this question before , can you cool your trailer down by spraying cold water on the roof?This would be common sense to me, however someone said it did not work too well
That the water evaporated very fast !!
- photo 2.JPG (124.78 KiB) Viewed 2372 times
Guess what, I tried it and just as I assumed it works great, it dropped my attic temp probe from 138 down to 90
in a matter of 30 - 45 minutes and it is still dropping. I would guess at this point the effect will last at least 1-2 hours,
I say this because my roof has a fair amount of standing water to help keep it cool.
Now this is with the silver roof. This would work much better if you had a white roof & maybe even better if
Your parked in the shade. If your camping maybe water is cheap , give it a try if you hot - why not try cooling your trailer.
- photo 3.JPG (99.89 KiB) Viewed 2372 times
This will also help for your solar panels to get cooler -
BUT BE CAREFUL THERE !!Try it out and let us know how it works out for you ??
The outside temperature today was 88 degrees F
Jerry
