AC choices
Re: AC choices
Postby Glenlivet » Wed Jun 12, 2013 6:35 pm
I just went with a window shaker 5200 BTU, in a wall mount. Intrudes less than four inches into the living space and cools it nicely.
From the outer wall it protrudes about 7 inches out. The wheels and fenders stick out 11 inches so it's not all that vulnerable and its on the non traffic side. The super quiet Champion 2000 inverter generator is plenty enough to power it and when running the A/C it operates on the lowest throttle step (of four), except for the starting surge when it revs up.
Glenlivet
Re: AC choices
Postby Myates » Thu Jun 13, 2013 11:50 am
Did you fabricate the trim around the inside and outside??
22 Because of the Lord’s great love we are not consumed,
for his compassions never fail.
23 They are new every morning;
great is your faithfulness.
Myates
Re: AC choices
Postby Glenlivet » Thu Jun 13, 2013 4:55 pm
Myates wrote:Did you fabricate the trim around the inside and outside??
Yes, they are made from 1.5 x 1.5" x 1/8" angle, mitered and welded. The inside mount box is riveted to the A/C case.
I wrote all about it when I did it last year, in this thread:
viewtopic.php?f=42&t=50223&start=45
Glenlivet
Re: AC choices
Postby Greenhead » Fri Jun 21, 2013 2:31 pm
http://www.youtube.com/watch?v=NZ6leXyLIBs
This guy did not like the ClimateRight... They do have a 5000 btu unit now.
Shadow Catcher, you should make the conversion kit for people to buy a specific AC unit and then install.
I would buy one!
6" x 12" V nose Stealth CT
Greenhead
Re: AC choices
Postby PubUltraStar » Fri Jun 21, 2013 3:33 pm
Wow, I was going to buy a climate right for my Tear. Now, I may have to do some more research, as it sounds like the support at ClimateRight is non-existent, and once you have the unit, you're on your own.
There is always risk in being awesome!
http://www.diy-teardrop.com/
http://www.m2-photo.com
PubUltraStar
Re: AC choices
Postby WildTexan » Mon Jun 24, 2013 9:27 pm
My solution....I mounted the window unit into the cabinetry and ducted it all through the floor. Works great.
WildTexan
Images: 77
Re: AC choices
The ducting under the trailer
WildTexan
Images: 77
Re: AC choices
Postby OverTheTopCargoTrailer » Mon Jun 24, 2013 9:40 pm
Are you from down under ? Where cold air goes up & hot air goes down ?
What size trailer is your unit cooling ?
Jerry
Re: AC choices
Postby WildTexan » Tue Jun 25, 2013 6:59 am
It's a 6x10. On a 100 degree day the area around the ceiling does get warmer, but a small fan does the trick. Also, I should say that my trailer is used strictly for sleeping only. We are rarely in it during the day so it usually isn't a issue. It gets plenty cold at night.
WildTexan
Images: 77
Re: AC choices
Postby hankaye » Tue Jun 25, 2013 8:35 am
WildTexan, Howdy;
Seeing those holes in your flooring makes me curious about
the condensation run off. Aren't you concerned about it rotting
the floor????? :thinking:
hank
hankaye
Re: AC choices
Postby WildTexan » Tue Jun 25, 2013 9:03 am
I've sealed the floor with a rubber coating and created a drain for the condensation. I'm going to spray the bottom with the same rubber coating.
WildTexan
Images: 77
Re: AC choices
Postby WildTexan » Tue Jun 25, 2013 9:06 am
I should note that this was a total experiment so nothing is certain, but so far it works great. The unit is accessible through the front in case I need to take it out for any reason. The floor is repairable, and the rubber sealant is under the cabinets.
WildTexan
Images: 77
