I went ot Lowe's and found a flooring adhesive trowel with the smallest notch I could find. I also got a spackling blade to scoop out the emulsion. I scooped out the emulsion, placed it on the trowel and then spread it on the floor. Then using the notch's, I got a consistent layer, then I used the flat edge and smoothed it out. I placed it out in the sun and in two days it was dry enough to mount my floor. I did the same with my infloor storage box.
I initially tried to brush this on and could not get a consistent thickness and it is very tough on your wrists trying to spread it around.
Just a little tidbit to make life a little simpler.
