Great connectors for 12v and custom tail lights
Anything electric, AC or DC
Postby webbaldo » Tue Jun 25, 2013 2:48 am
If you've done custom tail lights (and internal 12v) and need to do all your own wiring, I found these Lever quick connectors a godsend from a company called Wago
Here in the UK I get them off ebay or CPC, im assuming they are available worldwide.
Come in 2/3/5 connections etc, great for wiring Ground etc.
They are reusable and keep a super tight grip. They wont come loose
Handy if you are in tight spaces or need to reconnect stuff without cutting wiring.
I don't work for them but thought id pass the info on as I found them great to use.
I used them for a lot of my junction wiring for grounds and connecting to my 12v system in the TD. They can handle fairly high load ratings.
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Re: Great connectors for 12v and custom tail lights
Postby Woodbutcher » Tue Jun 25, 2013 6:50 am
Those are cool. I could see many uses for them. Thanks for the heads up!
Woodbutcher
Postby H.A. » Wed Jun 26, 2013 9:01 am
These things are handy ! But dry locations only.
I use alot of stuff from Wago, Primarily their DIN rail products.
H.A.
Postby webbaldo » Thu Jun 27, 2013 6:57 am
H.A. wrote:These things are handy ! But dry locations only.
Good point, they are not weather proof. I used them for my tail lights but all the wiring is hidden inside the hatch.
webbaldo
Return to Electrical Secrets
